shifter air lines
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Andres Guerrero, Nov 15, 2015.
  1. Andres Guerrero
    Andres Guerrero Bobtail Member
    30
    14
    Sep 3, 2015
    can anyone tell me what size are the shifter air lines for a regular 10 speed eaton fuller? are they all the same or do they vary?
  3. Straight Stacks
    Straight Stacks Paper Cha$er
    2,930
    20,768
    Jul 18, 2015
    Alabama Gulf Coast
    Still haven't found an answer yet!? LoL...Check this website. Should have what you need.
  4. Andres Guerrero
    30
    14
    Sep 3, 2015
    thanks lol i still cant find them man its been a pain in the ###!
  5. beemergary
    beemergary Light Load Member
    229
    112
    Apr 11, 2014
    My guess is 1/8" The ones Pro Gear sells are 5/32" I used 1/8" more common and got the lines at parts store. Why not just measure them? Mines a 13 speed.
  6. BoxCarKidd
    BoxCarKidd Road Train Member
    4,418
    6,431
    Aug 26, 2014
    1/8, 5/32, or 3/16. I don't thank 1/8's are marked but the others commonly are. Slide the cover down under the shirt knob, two screws, and look at the nuts.
  7. sparky88
    sparky88 Light Load Member
    143
    31
    Jan 22, 2014
    oswego, ny
    Mine on my 18 speed are 5/32
  8. beemergary
    229
    112
    Apr 11, 2014
    My Pete 13 speed came with the 1/8". The 5/32" suppose to give faster shifts which makes sense. Could never find the 5/32 ferrels or compression fitting in case I needed to do some repairs. But you can find the 1/8" fittings and line almost everywhere. Mine is kinda slow going from high range too low.
  9. sailboatjim
    sailboatjim Light Load Member
    292
    173
    Aug 27, 2014
    Boston, Mass
    3/16 on the spicer I'm working on.
    Found this quickly.
    Air Line Color Chart
    Eaton® Fuller® 5/32" air lines are color coded for easy identification.
    Use the follow chart along with the appropriate system schematic
    when troubleshooting and repairing your air system.
    Nomenclature Color
    S- Supply Red
    P-Pilot Black
    H/L- Splitter or Deep reduction Green
    A- Supply, Non-regulated Orange
    SP- Splitter pilot Blue
    B- Brake signal Yellow
    E-Exhaust Brown
    BRD TRANSPORT Thanks this.
  10. BRD TRANSPORT
    BRD TRANSPORT Light Load Member
    184
    69
    Jul 6, 2018
    5/32?
    spsauerland Thanks this.
