Shifted Leaf Spring
Discussion in 'Trucks [ Eighteen Wheelers ]' started by end of the road, May 27, 2011.
  1. end of the road
    end of the road Heavy Load Member
    868
    540
    Jul 4, 2010
    Northern Canada
    During my pre-trip I noticed one of the springs had moved. Did not shift left or right or back or forward but rather has spun or pivoted in place. The front is out 1 inch and the back is out one inch. These springs don't have the shackled to keep them in place, and the u-bolts are not loose.
    I asked one of the older guys and he said this is normal but I am not convinced.
    What does the dslbear say?
    NRT1945 Thanks this.
  3. JohnP3
    JohnP3 Road Train Member
    1,594
    683
    Feb 21, 2010
    Rock Creek B.C. Canada
    It is not normal, and if it continues can cause a problem. You want to write it down on every pre trip.
    It can be put back into place by loosening the "U" bolts, and with a hammer put it back.
  4. AUSSIE DAVE
    AUSSIE DAVE Road Train Member
    1,032
    176
    Feb 21, 2010
    OZ - Brisbane
    u must do a good pre-trip, keep it up. congrats
    KB3MMX Thanks this.
  5. Volvo92906
    Volvo92906 Light Load Member
    120
    63
    Jan 14, 2011
    Sounds like something broke.. Like maybe the aligning pin that keeps the springs centered? Possibly.. And I do not know if you work on your own truck but U-bolts are torque to yield so they cannot be loosened and re-tightened as JohnP3 stated.
    I do agree with Aussie Dave, great job on the pre-trip. I know a lot of drivers who dont look for this kind of stuff, but then again, what do you expect when they have people like me to check everything over when it comes into the shop?
    KB3MMX and ramblingman Thank this.
  6. kwforage
    kwforage Road Train Member
    1,047
    472
    Jun 3, 2007
    Wisconsin
    Mine shifted so I loosened the u bolts, pounded it back with a hammer, and made a clamp out of some bent steel and a bolt.
    R29saldivar Thanks this.
  7. end of the road
    868
    540
    Jul 4, 2010
    Northern Canada
    Yes, my pre-trips are thorough. I am paid to do a thorough pre-trip so I do. I like it that way too. I feel better about the vehicle I drive.
    There is no way that u-bolt is going to be loosened and re-tightened. Here in the land of rust they are cut off with a torch and replaced when springs are changed. I find it odd that there are no shackles keeping them aligned.
    So the question remains, is it an OOS defect or just a normal thing that should be monitored?
  8. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    can you post a pic? I am interested in seeing what you are seeing.
    safeyankee Thanks this.
  9. canuck in da truck
    canuck in da truck Road Train Member
    4,352
    2,601
    Aug 6, 2010
    western pa
    its more than likely the centering bolt loosened off a bit--you can do like was posted --put a clamp over it when you get it straight--hmm but since you are hauling propane---i would take it to a shop--they can put a new bolt in it--replace the u-bolts and good to go
  10. Heavyd
    Heavyd Road Train Member
    7,749
    6,184
    Feb 4, 2009
    Is this like the small back up spring under the main one? Ubolts are starting to come loose.
  11. concdriver
    concdriver Bobtail Member
    46
    13
    May 19, 2012
    cambridge,on
    Same with my truck. It was sitting on jack on one side when the shop told me to pull the truck out. As soon as it was off the jack something snapped and broke. I could hear the noise and vibration ( It happened after it was off the jack app 10 feet). Immediately my steering became very light. It has been about a year. Since then 10 shops and 6 dealers have looked at it and they cannot find anything wrong. 4 guys have done the alignment and still no change. I had this put on the Vis check machine and it came out clean. I want that heavy steering feel back, it felt much safer. Out of frustration I started throwing parts at it and replaced king pins and steering gear box. Still no change. I had also noticed that my spring if off by abt 1 inch just like yours. I am planning to change the bushings and the centre pin when I am back from my next trip. Did you get this figured out yet. Plz help if you did. thx
