Shift tower sloppy?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by SHC, Aug 20, 2014.
  1. SHC
    SHC Spoiled Rotten Brat O/O
    8,484
    7,046
    Feb 26, 2011
    Westville, IN
    Ok, my shifter has gotten super sloppy lately. It goes into gear and out just fine, so it's nothing with the gates. As i wiggle the shifter tho, i can see it wobble around on the top of the rod that comes out the top of the trans. Is there a bushing or grommet that goes where the shifter mounts to the top of the trans rod (like a ball and socket set-up maybe?). Just wondering. it's an eaton 13spd
  3. wore out
    wore out Numbered Classic
    15,319
    184,961
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    There is a rubber isolator in the bottom of the stick.
    SHC Thanks this.
  4. Licensed to kill
    Licensed to kill Heavy Load Member
    830
    2,434
    Dec 31, 2010
    Alberta
    It sounds like the isolator to me as well. Changed one on one of my Western Stars and added one to my old Ford (it didn't have one).
    SHC Thanks this.
  5. SHC
    8,484
    7,046
    Feb 26, 2011
    Westville, IN
    That's what I figured. Gonna pull it apart Friday since I'm off. Thanks
  6. JohnP3
    JohnP3 Road Train Member
    1,594
    683
    Feb 21, 2010
    Rock Creek B.C. Canada
    The shifter ball has a key way in it, they get worn usually from people driving with there hand on the shifter, I needs to be removed it can be done thru the shifter boot, and welded up and all will be great, might need a new Key as well.
    A gasket and a key a little welding and cut with a high speed cutter. They come apart from the inside.
    Just a thought!
  7. BeenJammin
    BeenJammin Light Load Member
    256
    118
    Dec 17, 2013
    Isolator x 3 . Question is, which SOX? Red or white? I'm guessing red, being crimson is already one of your favorite colors.
  8. SHC
    8,484
    7,046
    Feb 26, 2011
    Westville, IN
    Chicago White Sox of course
  9. Semi Crazy
    Semi Crazy Road Train Member
    3,033
    2,044
    May 13, 2011
    Middle Tennessee
    Wore out O-ring on top of the ball.
