Does anyone know the shift pattern for a 93 Mack with a 13 speed in it.Will be starting a local job hauling feed and that is what they have in there trucks.Thanks in advance for any help.
shift pattern for mack 13 speed
Discussion in 'Questions From New Drivers' started by Thomas0810, Apr 24, 2009.
what exactly do you wanna know I've driven all kinds of macks but the 13 speed was an o5
you basically have reverse (hi,lo) low then 1-4 flip it up and you have hi,lo in 5-8
like a 10 speed is 1-5,hit the splitter 6-10,i noticed the gear shifter has the splitter and a red switch on the gear shifter also
well kinda but you'll split after 4th and the red splitter is for your hi lo 5-8. when you reach your Rpm red switch up let off accelarator then hit accelarator again and it will catch your next gear. then when you reach RPM red switch down and hit 6 and so on so on. Its easy man you dont have anymore holes just more splitter action
It is a 9 speed pattern. 1-5 on the low side. Then 6-9 you can split hi-low by using the red button. It is not difficult. If you understand a 9 speed pattern you will pick up on how to split 6-13 fairly quickly. Just remember to pre select your gears.
You have the capability of HI or LOW range in the upper gears by using the red switch . -
ya I wasn't sure on the 93 but I know on the 05 you can split 5th also. But you explained it better lol thanks ampm
yes sir, they count your lo as 13 so its 1-4 then 5-8 hi-lo but like I said I'm not sure bout the 93
P.S I like the Mack on your profile.
