SHDN OVRD button?
Discussion in 'Freightliner Forum' started by RERM, Feb 23, 2015.
  1. RERM
    RERM Road Train Member
    1,683
    1,124
    Dec 13, 2012
    Chicago, IL
    I have a 2006 Century S/T class with a 14 L S60....what is this button for?....Operators Manual doesn't say.....and, from the drivers seat I can't tell any effect.....I know it's not a self destruct, other than that ?????
  3. Dna Mach
    Dna Mach Road Train Member
    3,251
    2,955
    Aug 8, 2008
    Texas
    The truck will shut down if the computer senses a situation that will cause harm to the engine. The shut down over ride button allows you a few minutes to get the truck safely parked if need be. I have never once used the button despite having several trucks equipped with them.
  4. Pedigreed Bulldog
    7,737
    14,421
    May 7, 2011
    Shutdown Override. If the ECU throws a code and is going to shut down the engine (i.e. blown hose and you lost all of your coolant) that button will buy you an extra 30-60 seconds to get the truck out of the way before the engine shuts itself off.
    RERM and 77smartin Thank this.
  5. RERM
    1,683
    1,124
    Dec 13, 2012
    Chicago, IL
  6. Krashdragon
    Krashdragon Medium Load Member
    651
    305
    Apr 10, 2012
    Cleburne, Tx
    Thanks. Have one on my truck but had no idea what is was for.
    Now if I just knew what the big red button on the dash is for....
  7. ironpony
    ironpony Road Train Member
    17,502
    12,015
    Sep 23, 2007
    Ask my GPS...
    If it's an old Prime truck, that's the security panic button. If you're in a hijack situation for example, it will get the attention of the security people via QUALCOMM post haste. Don't know if it would still be activated in your case.
  8. OldHasBeen
    OldHasBeen Road Train Member
    1,269
    924
    Dec 16, 2010
    Such a button would be nice.
    Years ago working for a company another driver was going down University Avenue at Little Rock loaded during the busy morning traffic and his truck shut down on him and he could not get out of the way. If its temp got over 200 degrees it shut down no matter where you were, instantly. This company was running about 60 conventional KW's and that is the only truck I ever heard of doing that during my 5 to 6 years driving for them.
  9. mhyn
    mhyn Road Train Member
    4,255
    4,510
    Dec 29, 2008
    Northridge, CA
    people you have forgot to mention the second and important feature of that button. The fault code flash reading ....))))))))
    Rideandrepair and baha Thank this.
  10. magoo68
    magoo68 Road Train Member
    3,393
    5,385
    Jun 11, 2011
    st malo mb canada
    Had a Cascadia go into shutdown mode because of a wiring issue it wouldn't do a burn - 25 snowing and 120 miles from next town (up north) I jimmied a paper clip to hold button and made the trip in derate mode .. Tows up in northern ontario can run you 3000 easy ..
  11. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    It is also used to get flash codes. On a Detroit, if you push that button, the amber light will flash stored codes, the red shutdown light will flash active codes.
