Shaking while driving
Discussion in 'Trucks [ Eighteen Wheelers ]' started by ach1998, Apr 8, 2021.
  1. ach1998
    ach1998 Bobtail Member
    4
    Apr 8, 2021
    I have a 2016 international, recently when I start to go anything from 50-70mph my steering wheel and pretty much the whole truck starts shaking, it’s shaking at it’s worst at 50-60 but 70 it reverts back to normal, what could be the cause of this?
  3. bowhunter67
    bowhunter67 Light Load Member
    283
    549
    May 28, 2016
    rush city mn
    Tires out of ballance or round will cause this.
    Dave_in_AZ Thanks this.
  4. beastr123
    beastr123 Road Train Member
    2,805
    22,863
    Jan 2, 2014
    Moose Jaw SK CAN
    tires
    steering gear loose
    air ride deflated causing bad u-joint angles
    loose drive shaft yoke
    worn u-joint
    These are all things that can cause a bad vibration or "shake" but not all that can
  5. ach1998
    4
    Apr 8, 2021
    Gotcha my steer got low tread, gonna get it changed out, have them take a look as well
  6. John E.
    John E. Light Load Member
    239
    973
    Apr 4, 2021
    New Brunswick
    Could possibly be your carrying bearing. This bearing will cause a lot of shaking or vibration on your rig when worn out. You can check it with a pry bar for up and down movement or side to side movement.
    Not that expensive to replace.
    201 Thanks this.
  7. 201
    201 Road Train Member
    12,058
    24,619
    Apr 16, 2014
    high plains colorado
    Vibrations are always tough, it could be many things. If the shaking is in the steering wheel, chances are it's up front. Hitting a curb can break a belt in the steer tire, and wheel bearings too. If the shaking is in the seat, it's probably a driveline bearing. I heard bad harmonic balancers cause vibrations up front too.
  8. ibcalm19
    ibcalm19 Road Train Member
    1,463
    2,435
    Nov 30, 2015
    Pennsylvania
    I would get that checked out very quickly. I suffered one of the mega fails My carrier bearing was bad I made the bad decision to say ill get it changed in the morning. Make long story short drive shaft broke at front universal joint on transmission. The drive shaft tore all electrical wires & air lines just as I passed a truck. I thank the Lord the momentum carried me to the shoulder & I didn't cause an accident it was at night raining. Don't take unnecessary risks. All the best
    Smellfunny and tommymonza Thank this.
  9. Smellfunny
    Smellfunny Road Train Member
    1,445
    967
    Jan 28, 2012
    South Carolina
    Could be bad tie rod end or drag link or gear box issue. Stop and get it checked before someone gets hurt.
    ibcalm19 and tommymonza Thank this.
  10. tommymonza
    tommymonza Road Train Member
    4,519
    12,848
    Sep 10, 2013
    S.W. Florida
    I’m Sorry. I can’t help myself.
    Deere hunter, Roberts450 and 201 Thank this.
  11. 201
    12,058
    24,619
    Apr 16, 2014
    I liked Eddie Money, even if that wasn't his real name. He just died recently.
    tommymonza Thanks this.
