Shake when shutting off the key.
Discussion in 'Ask An Owner Operator' started by feldsforever, Jul 14, 2021.
  1. feldsforever
    feldsforever Road Train Member
    1,453
    1,440
    Nov 22, 2019
    2016 cascadia, dd13.
    Is increasing the engine shake when I turn off the key. And ideas?
  3. shatteredsquare
    shatteredsquare Road Train Member
    1,398
    1,825
    May 23, 2014
    middle dirt
    if it's at low idle it will shake like crazy back and forth, flywheel and crank and everything still connected and spinning, it rocks back and forth with the momentum of everything. if it's at high idle it feels like it disconnects from flywheel and crank and uses the engine brake to grab the cylinders as it shuts off, you hear little puffs of air and no rocking or shaking. on mine low idle vs high idle is only like 200 rpm difference, u hold cruiser accel button to raise it. if it's at low idle when you key off its pretty rough, if it's at high idle when you key off the engine brake grabs it like a marshmallow fist instant off and quick
    slow.rider and feldsforever Thank this.
  4. 86scotty
    86scotty Road Train Member
    4,373
    11,589
    Aug 27, 2017
    Appalachia
    Trucks just do that sometimes. Some more than others.
    feldsforever Thanks this.
  5. roundhouse
    roundhouse Road Train Member
    3,129
    7,022
    Jul 11, 2018
    Do the new trucks have the anti shudder valve ?
    It’s a flap that closes and cuts off the air so the engine doesn’t shake as much when it stops .
  6. feldsforever
    1,453
    1,440
    Nov 22, 2019
  7. darknessesedge
    darknessesedge Medium Load Member
    650
    423
    Jul 8, 2013
    if it shakes more than 3x....your playing with it
    Magoo1968, Vampire, LameMule and 4 others Thank this.
  8. shatteredsquare
    1,398
    1,825
    May 23, 2014
    middle dirt
    my DD13 low idle is 600, high idle is like 750...if u key off at low idle it bangs around, if u key off at high idle it farts to a instant stop without any shakes, sounds just like an engine brake
  9. roundhouse
    3,129
    7,022
    Jul 11, 2018
    All of my old trucks would stop the engine so hard it would shake the truck and squeak the fan belts .
  10. AModelCat
    154,214
    Magoo1968 and feldsforever Thank this.
  11. darknessesedge
    650
    423
    Jul 8, 2013
    lol
    Magoo1968 Thanks this.
