Setting up a 30 ton mechanical winch
Discussion in 'Heavy Haul Trucking Forum' started by Marmon110P, Jul 2, 2019.
  1. Marmon110P
    Marmon110P Light Load Member
    177
    183
    Feb 24, 2019
    So Ive got a 30 ton mechanical winch in good shape that I got for a bargain price. Im wanting to put it on my cabover with a 18918B tranny. Yes, I have plenty enough frame space and most of my winching experience as a company driver is with mechanical winches in the oilfield...and Ive ordered new cable for it. Im wondering if I can hook it to a PTO driven off the tranny (I have one of those also) or how would these mostly be rigged up?
  3. truckdad
    truckdad Road Train Member
    2,020
    16,623
    Dec 14, 2014
    Penn Valley, CA
    Marmon, I've had both types. You can drive it with a hydraulic motor as I did in the first pic. Or drive it off the PTO. You will have to do some calculations to get the winch speed you want or just take the info off someones setup you like. As you may know, mechanical drives will pull til the cable breaks. The hydraulic drive I had was ran by a simple woodsplitter valve and could be adjusted. It didn't have near the pulling power the mech did, but in a pinch, I could have any idiot off the street work the valve while I drove the dead tractor or whatever. And a snatch block was always available for when its too hard of a pull.
    cke, Oxbow, Marmon110P and 8 others Thank this.
  4. beastr123
    beastr123 Road Train Member
    2,805
    22,858
    Jan 2, 2014
    Moose Jaw SK CAN
    If your winch is equipped with a reversible transmission built in a mechanical drive is great as long as you are the only one to operate it. Running a shaft back from the pto to a steady bearing and a chain drive to the input of the winch with a shearpin in the lower shaft is almost unbeatable for true pulling power. If the winch does not have a reversing lever on it the only was to mechanically drive it is with a reversing pto.
    if that winch is not equipped with a guide plate to control the "lay of the cable" then plan on re-spooling the cable every time it is used and replacing the cable because of flat spotting from overlays under load. For this reason winching from inside the cab without a direct view of the winch is not a great idea. This is why most winch trucks are daycabs and many have rolldown windows in the back.
    this is a great reason to go hydraulic drive with outside controls even if the tank and oil will add extra weight. if you tune your pressure bypass you may not need a shearpin in the drive for protection.
    Marmon110P, stwik, BigBob410 and 2 others Thank this.
  5. ETMF 58 White
    ETMF 58 White Light Load Member
    90
    218
    Jan 4, 2019
    A terrible disappointing memory from my early teenage years was how I let my dad down winching a dozer out of the mud. It was a pretty big dozer, and it was down bad. We pulled the old winch truck, which looked similar to truckdad’s photos except it was single axle, into the job site with a big tractor and spun the tractor tires down to make a deadman to hold the truck. Then snatch block the cable to the dozer and a distant tree. Started the pull, and the dozer finally started to come out, the operator being careful to help a little but not spin the tracks. I was running the winch truck. Sometime during the pull the cable slipped down into the fifth wheel jaws. I saw it, but didn’t stop because the dozer was finally coming up. I remember debating in my mind whether to stop and get the cable out of the fifth wheel. But I didn’t.
    When it was all over, I had to show dad how the cable was splintered for a good distance from pulling through those jaws. He was mad, but didn’t whip me with his belt.
    That cable is still on the old winch truck, which hasn’t moved from its resting spot at the back of the yard in over 30 years.
    cke, REO6205, Landincoldfire and 3 others Thank this.
  6. Marmon110P
    177
    183
    Feb 24, 2019
    The PTO I have is a 2 way (fwd n reverse) so I think that's good. The one issue I'm not sure of is what I need for a PTO speed. The one I have was use for driving a 4.5" crude oil pump so it's likely around a .75 or there about I'm guessing.
  7. beastr123
    2,805
    22,858
    Jan 2, 2014
    Moose Jaw SK CAN
    You should be able to contact the manufacturer with the model # and serial# and ask for the ideal input speed of the winch.
    Plan to gear it to hit that speed at engine 2000rpm with the chain riser from the pto shaft (or hydraulic motor if you decide to go that route).
    That will give you a smooth engagement with throttle response to vary your pulling line speed and torque.
    Oxbow and Marmon110P Thank this.
  8. Marmon110P
    177
    183
    Feb 24, 2019
    I jut found out that the truck the winch came off of is being parted out and they have the PTO, driveline, lowbed ramps and tail roll w/ apron all available now...for $2500...seems like a deal...and then its all rigged properly.
    cke, MartinFromBC, truckdad and 2 others Thank this.
  9. truckdad
    2,020
    16,623
    Dec 14, 2014
    Penn Valley, CA
    So Marmon, tell us what you are going to be doing with a 30 ton winch on the back of a cabover?? Just wondering here...…………….
    cke, REO6205, kylefitzy and 1 other person Thank this.
  10. Marmon110P
    177
    183
    Feb 24, 2019
    Well the plan is to mostly use it for witching camp shacks on and also I'm looking to get a scissor neck trailer to make loading equipment easier...mostly what a conventional winch truck would do, but about 7' shorter...
    cke, MartinFromBC, kylefitzy and 2 others Thank this.
  11. m16ty
    m16ty Road Train Member
    2,265
    4,942
    Jan 22, 2016
    You’ve got to be careful running a winch off a side mounted or bottom mounted PTO. These are lighter duty PTOs and have a max torque rating, I’ve seen them ripped off the transmission because somebody tried to get too much torque out of them.
    Most transmissions have a PTO option off the back (powered by the mainshaft) or on top of the transmission (power tower). Both of these setups usually are rated for max engine torque, and is how most big oilfield winches are driven.
    Hydraulic drive is a good option, but it’s going to take a big motor and pump, or it will be painfully slow and/or not enough torque.
    cke Thanks this.
