setting pto backlash help
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Collie, Oct 12, 2019.
  1. Collie
    Collie Guest
    I have a muncie 489 unit. Mounts uderneath a rtlo trans. Im reading onlne it says to set backlash at (.006-.012). What does that exaclty mean? I swear the place whre the unit came from said to set at .015 but not 100 percent sure.
    What is a safe number? what does .006-.012 mean in idiot terms? .006 is the minimum and .012 is the max?
    Thanks
  3. Goodysnap
    Goodysnap Road Train Member
    3,694
    8,948
    Jul 12, 2017
    Yes, anywhere between 6 and 12 thou. Dial indicator measuring gear lash with the side cover off. You are measuring slop in the gear contact for oil clearance and no binding of bearings. Too tight add thicker gasket and too loose take some out at the PTO mounting.
    I usually mic the old gaskets for a starting point and start there. If it was set up right to begin with you should be spot on.
  4. Collie
    Collie Guest
    thank you.
    Reinstalling a pto on my new trans. and want to set drive gear lash of trans gear
    yes i will mic the old gaskets for a starting point to see where it was at. but this is old truck and i found that after working on it, it spent its life dealing with half assed mechanics so i just want to be spot on. I picked up two .010 gaskets and two .020 gaskets to make the correct adjustments
    Thank you again my friend
    Goodysnap Thanks this.
  5. Goodysnap
    3,694
    8,948
    Jul 12, 2017
    Yes for sure to measure when changing components as the gaskets required will surely be different.
    Same parts is almost always the same thickness.
    Collie Thanks this.
  6. spsauerland
    spsauerland Road Train Member
    4,296
    10,886
    May 31, 2010
    West Harrison, In
    489 would be a Chelsea PTO. Dial indicator is a must. With used gearing, shoot for the higher end of spec. 0.010" of gasket changes backlash approximately 0.006". When setting up, I usually only put four fasteners to get in ballpark and start with a thick and thin gasket. Final torque with all fasteners usually crushes gaskets an additional 0.002-0.003".
  7. Collie
    Collie Guest
    yeah i couldnt figure out why i couldnt find the part number. I guess m unit is old. Says muncie on it. I bought a new air shift for it ut all the gears and bearings are solit as can be. And thank you for the additional info for setup brotha
    spsauerland Thanks this.
  8. BoxCarKidd
    BoxCarKidd Road Train Member
    4,418
    6,431
    Aug 26, 2014
    I normally take the shift cover off the pto. Put a pry bar through the the cover and lock down the countershaft that drives the pto. Then move the mating pto gear to check clearance - backlash.
    That is where you would use your dial indicator. Must have a little freeplay.
    If to tight it will be screaming. If to loose it will sound like a rattle trap - knocking.
    Follow the other folks directions and you should be fine.
  9. pushbroom
    pushbroom Road Train Member
    1,777
    7,253
    Sep 1, 2012
    A 10 inch extension on a dial indicator makes it alot eaiser
  10. Working2party
    Working2party Medium Load Member
    608
    729
    Feb 10, 2018
    Kansas
    I’ve mounted lots of PTO’s on ‘01 and newer trucks. I’ve got a feel for it, but it’s pretty simple. A thin gasket adds .006 backlash, a think adds .012. You can do it without a dial indicator by Adding a stack of gaskets and removing thins till it’s out of lash the add a thick (or two thins) to land in the range .006-.012
    I usually start 2 thick & 2 thins, tighten 4 bolts, if the idler gear gets tight while tightening. add a thick and thin then re check.
    If you think it’s right, (has about the same lash on the transmission gear to idle gear as it does on the slide gear to idle gear). remove a thin and check for “zero lash”.
    If it goes zero lash, add a thick and bolt it up. Your done.
    If you still have lash, remove a thin and recheck for zero lash. Then add your thick (or 2 thins) your done.
    But normally since 01 transmission machining has gotten good enough 2 thick, 2 thin gets most of them.
    If you are using a dial indicator and find your self close but still alittle loose, give it about 15 min and retighten. After the gaskets at given time to compact, sometimes, your can get just alittle more That will also help keep them from seeping oil later.
  11. starmac
    starmac Road Train Member
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    It is always better to be a little loose than a little tight too.
