I have Service DEF, vehicle 5 ml per hour issue, got it from Volvo dealer a week ago and it is the same thing, they cannot fix it, any idea?
Discussion in 'Experienced Truckers' Advice' started by Vle, Mar 16, 2018.
Page 1 of 4
make sure insurance is up to date and let it burn to the ground
slow.rider, D.Tibbitt, 88228822 and 7 others Thank this. -
Pull the speed sensor off the back of the tranny and go to where you gotta be.
D.Tibbitt, 86scotty, BUMBACLADWAR and 1 other person Thank this. -
Engine derate. The last step before shutdown. Bad def line?
Could be a number of things, I just went through this with mine. First was a bad DEF pump, then a doser valve, both times it indicated that it was going to put the engine in derate and it didn't happen. But if you don't want to do the 5 mph thing, pop the sensor off.
RubyEagle, BUMBACLADWAR and MACK E-6 Thank this. -
Derated by how much?
slow.rider, D.Tibbitt and MACK E-6 Thank this.
slow.rider, D.Tibbitt, Lepton1 and 3 others Thank this.
Sounds like a possible DEF volcano in the SCR box. Any idea if the SCR system has been serviced? Like removed, power washed and inspected? They can be a real mess, if that is the issue. Agree with Ridgeline, lazy mechanic. Buy some tools and educate yourself on these systems, these shops will bankrupt you. My truck is going back together right now in my driveway.
Lepton1 Thanks this.
Page 1 of 4
