Serious / XM Radio antenna
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by HaulinCars, Jan 29, 2017.
  1. HaulinCars
    HaulinCars Medium Load Member
    355
    480
    Jan 25, 2014
    Central Florida
    I'm new to the satellite radio deal and have an antenna question.
    I'm currently using the little magnetic antenna that's about the size of a box of matches that came with my radio. It seems to work OK except when going under an overpass.
    I have seen the antennas that look like an inverted shot glass on the top of a stick about 12-18" long that the sell at the truck stops. (About $60 if I remember correctly). I have seen them mounted on some trucks but have never had the opportunity to talk to the driver of said trucks. (Seems nobody has or uses a CB anymore...).
    My question is do these antennas really work any better than the small magnetic one that came with my radio or is it just another way to pry $$ out of my itty bitty wallet?
  3. STexan
    STexan Road Train Member
    14,963
    29,153
    Oct 3, 2011
    Longview, TX
    I don't think they work any better. They are said to "amplify" the signal, but in the digital world, amplification of a weak, missing signal is still a bad signal. The one that is mounted highest and can get best line of site over any [metal] part of vehicle and nearby terrain, to the satellite is going to provide the most reliable signal.
    I've found that obstructions to the south and west of the vehicle are going to cause then most interruption of signal on my XM subscription and mine is factory mounted at the very top of the Cascadia full sleeper. And the further east and north you go, the easier it is to get obstruction interference.
    HaulinCars and chopper103in Thank this.
  4. lonewolf4ad
    lonewolf4ad Road Train Member
    7,743
    7,773
    Nov 4, 2008
    Displaced to Colorado
    I have used both, and IMHO the antenna you mount on the outside is MUCH better than the small cheap magnetic one. The only thing better is the factory ones some trucks have, as they provide the best direct line of sight.
    HaulinCars Thanks this.
  5. STexan
    14,963
    29,153
    Oct 3, 2011
    Longview, TX
    I assume the magnetic would also be mounted somewhere on the outside such as stuck on top of a mirror or outside visor. Any inside antenna setup is going to only work well about half the time, when going the right direction.
    I've had great results with the little magnetic mount puck stuck to the top of the driver side mirror on a cascadia with 3m 2-sided tape.
  6. HaulinCars
    355
    480
    Jan 25, 2014
    Central Florida
    Correct, it is on the cab roof, left front corner right behind where the visor mounts. Clear 360° view of the sky.
    Like I said it seems to work OK but I would like to fix the overpass issue IF it can indeed be fixed at all. I totally get it if I'm sitting under one at a light or whatever, but for the brief time I'm under it while driving and it goes out that just bugs me... By the way, highway speeds don't seem to bother it much, city speeds yes.
    Lastly, your 100% right about any inside (dash?) Mounting. That would just be stupid. Unless only ever drive headding South... LOL.
  7. STexan
    14,963
    29,153
    Oct 3, 2011
    Longview, TX
    My factory mount top of roof will cut out momentarily on maybe 25% of bridges. A lot of that has to do with the size of the buffer in the receiver. A handful of pricier receivers have a larger buffer that is larger than most bridge crossings duration.
  8. Aradrox
    Aradrox Heavy Load Member
    900
    622
    Jan 21, 2016
    If you head south long enough eventually your heading north
  9. HaulinCars
    355
    480
    Jan 25, 2014
    Central Florida
    Now that you say that I seem to remember something about buffer or something like that. I'll pull out my manual and see if there is a setting that needs attention. Even a buffer of only 5 seconds should be enough to fix my bridge issue assuming it is available to my unit.
    Thanks!
  10. longbedGTs
    longbedGTs Heavy Load Member
    974
    717
    Texas
    Mine is so bad that it's better to sing songs in my head than listen to the Sirius radio. It cuts out so much and the little magnetic antenna is just above the windshield on the passengers side(no visor). Here's one on ebay(not paying truck stop prices if I can help it) http://www.ebay.com/itm/TRAM-Satell...523944?hash=item463d432f68:g:K-AAAOSwu1VW7ask
    On a Cascadia though, I have no idea where I'd mount this thing, but can make a bracket and use a mirror mounting bolt if this thing is worth it. Or...maybe behind the sleeper poking up from the top just above the roofline. Any ideas?
  11. HaulinCars
    355
    480
    Jan 25, 2014
    Central Florida
    As I sad initially, I'm new to the radio portion of satellite reception, but I do have some experience with using satellite for TV so part of my answer here is based on my experience with that. I'm just guessing here (somewhat educated guess but in no way expert!) but it sounds like you may have 1 of 2 different problems.
    1) Defective equipment: You may have an internal problem with the antenna, antenna wire, antenna to radio connection or the radio itself.
    2) Signal reception: The other problem might be either the antenna is not mounted flat so that the top (the "antenna" part of the antenna) is not pointed up but is instead at an angle. Or with the way the roof of the truck is so much taller than the antenna mounting location, depending on which direction your truck is pointed, I suppose it is possible that the truck itself is interfering with a clear direct unobstructed view of the satellite, (especially if the antenna is not mounted flat)
    Assuming that your problem is not the radio itself (which is of course possible but most likely not the problem) replacing the antenna with a properly located one should fix all of the other issues at the same time so if your willing to just go replace it trying to figuring out exactly what the problem is should not be necessary, (unless of course it actually is a problem with the radio itself, then replacing/relocating the antenna 100x will not make any difference).
    That said, I'm not sure a mirror mount would not still be blocked from proper unobstructed view of the right part of the sky depending on direction of travel. Assuming the provided wire is long enough, mounting behind the sleeper on the back wall sticking up slightly above the roof should be ideal as it would give 100% clear view of the correct part of the sky no matter what direction the truck was pointed.
    Perhaps another Cascadia owner can chime in with what they did and report on how is working for them...
    longbedGTs Thanks this.
