Series 60 serial number missing ?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by areelius, Apr 11, 2013.
  1. areelius
    areelius Light Load Member
    270
    119
    Nov 9, 2012
    Temecula Ca
    Can someone please post a photo of the serial number location on a 1993 through 2005 60 series Detroit? I have an engine which seems to be missing the ID tag or whatever Detroit used to mark the number. The ecm has been changed to a different year and is not showing the right engine. I have looked this up many times online and have talked to several experts without success. There are numbers cast into the block in 2 different locations, on the drivers side which are about 1/2 inch high, but they don't seem to be the serial number. If anyone can show a photo of an engine like mine with the serial number clearly visible it would be very helpful.
  3. carrkool
    carrkool Heavy Load Member
    883
    495
    May 10, 2012
    adah, pa
    mine is on the sticker on the vavle pan....i will look and see if that matches any cast numbers
    areelius Thanks this.
  4. Acm
    Acm Bobtail Member
    20
    5
    Feb 28, 2013
    Should be on the bottom of the decals of valve cover.Think it usually starts with an L and then 5 or 6 digits.
  5. rebel127
    rebel127 Light Load Member
    296
    149
    Feb 28, 2011
    monroe ct
    It is on the center of the block rite under the intake manifold just below the head gasket. You may have to clean it with scotch brite and brake clean its a flat square boss.
  6. Ridgeline
    22,602
    119,987
    The numbers cast in the block are casting numbers nothing to do with the serial number. These are either production numbers for the block or part numbers or both.
    By the way, why are you asking for a picture?
    Did you call Detroit - just curious?
  7. fortycalglock
    fortycalglock Road Train Member
    6,157
    6,587
    Jun 25, 2011
    Tourist Town, FL
    Like rebel says, under the intake. Fairly large font. Clean the area and rub some chalk on it to see it.
  8. bubbanbrenda
    bubbanbrenda Road Train Member
    1,388
    650
    Feb 27, 2011
    Middletown,Oh.
    really, arguing with Rebel...this ought to be good.
  9. rebel127
    296
    149
    Feb 28, 2011
    monroe ct
    They are stamped on the flat square boss or if it is an 06re# there will be an aluminum tag riveted to the boss.
  10. rebel127
    296
    149
    Feb 28, 2011
    monroe ct
    No argument needed I would hope he miss understood me.
  11. Ridgeline
    22,602
    119,987
    Arguing about what?
    I may be wrong, I can admit to listening to those who built the thing as their explanation is accurate info but they've been wrong too. They said they stamp the serial number on the block, not cast it - they cast the numbers in the block for production purposes like part numbers.
