Series 60 12.7 best year to buy?
Discussion in 'Ask An Owner Operator' started by istumped, Apr 11, 2024.
  1. istumped
    istumped Medium Load Member
    493
    233
    Feb 8, 2015
    Looking at a few cores to keep on hand to maybe rebuild for the just in case situation. 92,93,(both 450 hp)98 500hp. These currently do not run. Would you buy all three or buy just one? I'm leaning towards the 98. What say and why?
  3. Big Road Skateboard
    5,686
    29,601
    May 2, 2021
    I like the DDEC IIII engines. More features available in the DDEC system increaaing driver comfort and fuel economy.
    Rideandrepair Thanks this.
  4. Elroythekid
    Elroythekid Road Train Member
    2,604
    5,655
    Sep 9, 2010
    Halifax Nova Scotia
    I'll second d deck 4
  5. Rideandrepair
    17,202
    55,794
    Aug 8, 2015
    98 because it’s drilled for wrist pin oil squirters for cooling. It may already have them, or you can add them. The blocks are all drilled, some are capped off. Plus it’s a ddec lV. Same as ddec lll, I think the only difference is lV has a battery for saving stored codes when starting battery power is lost. I believe the even older ones didn’t have injector calibration ability. Also originally didn’t have waste gated turbos. You can rebuild it any way at you want. Original 2 piece trunk style rods and 15:1 pistons, or using a BK kit w the higher 16:5-1 compression pistons w/floating wrist pins instead of 2 piece rods if that’s what it currently has. You‘d need to buy new rods. Higher compression pistons eliminates the excessive smoke on start up. You can even upgrade to the newer drilled rods if you’re going to be buying them anyway. The older pistons are fine. Maybe even get better mpg. That’s my experience. Had a 98 PK and a 99 BK. I think the BK had better power. It’s hard to say. 98 had 6 hole injectors 99 has 9 hole injectors, maybe to combat smoke? Better atomization for higher compression pistons maybe? 99 seems to idle smoother. From what I’ve read the 6 hole injectors are more responsive. Just things I’ve read doing research on mine. They’re all good. Limited on max hp without oil squirters. It was very common to have a wrist pin come apart right about 750k. Half the time knocking a hole in the block, supposedly depending on direction of stroke when it failed. I once met an O/O that had that happened to both of his Trucks in the same week. Both had mid 700k miles. First I’d heard of it. He was a Diesel Mechanic himself. His son in law drove the other Truck. Both were stock, maintained and driven right. That’s all I know. Just repeating things I’ve learned, mostly on this sight. It’s all here to be found. Just my opinion, best rebuild would be with the newer 2000? and newer drilled rods, BK pistons, maybe 6 hole injectors for better pedal response. I don’t really know exactly what’s possible. There’s choices though. There’s hotter cam that requires a different gear maybe? The real expert here is @benjamin260_6 he can advise best on 12.7. Worth looking up his posts. You’ll learn a lot.
    blairandgretchen and 77fib77 Thank this.
  6. benjamin260_6
    benjamin260_6 Medium Load Member
    430
    480
    Aug 8, 2012
    Ontario, Canada
    I'd get the '98 for sure. The other two, based on the year, are ddec ii. They would be OK in a mostly stock application but I wouldn't even bother with them, personally.
  7. pavrom
    pavrom Road Train Member
    3,162
    7,247
    Apr 29, 2012
    NE illinois
    I heard once from Leon that 05-06-07 14l are best detroits...
