Septic Waste
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by AriGab, Jan 11, 2025.
  1. AriGab
    AriGab Light Load Member
    60
    27
    Feb 3, 2023
    Hey just curious if anyone on here hauls septic waste? I have done a ton of research and Google says that a gallon of septic waste is the same as a gallon of water (8.34 lbs). I truly find this hard to believe. Does anyone have real world numbers from crossing scales with a tanker or septic truck? Thanks.
  3. Lav-25
    Lav-25 Medium Load Member
    542
    821
    Mar 31, 2018
    That weight is okay for liquid , sludge and build-up are little heavier ( paper , cooking oil , etc ) . If its bobtail tanker not a big issue , but the stuff you get from a sewage plant is ususally a mass of sludge with a heavier weight.
  4. AriGab
    60
    27
    Feb 3, 2023
    So I pump septic tanks and I'm trying to figure out actual weight per gallon.
    broke down plumber Thanks this.
  5. broke down plumber
    2,598
    18,560
    Jan 25, 2024
    Never seen a tank over 2k gallons on a single drive axle truck.
    Lav-25 Thanks this.
  6. broke down plumber
    2,598
    18,560
    Jan 25, 2024
    Its gonna vary due to consistency, a thick crust and lots of gunk in the bottom will weigh different than one thats mostly water like after a heavy rain event when field lines have become saturated and are back dumping into tank .
    Lav-25 Thanks this.
  7. Lav-25
    542
    821
    Mar 31, 2018
    Yep , used to take the small trucks out , pump out the tanks and such , bring it back to yard , pump it off into the big truck and empty it at sewage plant once a week .
    Paid the bills , smelled awful but paid above average. Back in 91
  8. Lav-25
    542
    821
    Mar 31, 2018
    The weight would be 15,000 lbs in a 1800 gal tank roughly . Most of them pump trucks have a waste tank and a replacement tank for wash downs and refills ( like for portapottys)
  9. Ridgeline
    22,116
    113,324
    You are right, but if the effluent has a lot of solids and sludge, then add 10%, this seems to be the average, even if the sludge and solids are macerated.
    Lav-25 Thanks this.
  10. Lav-25
    542
    821
    Mar 31, 2018
    Wasn't a bad gig , worst part was the smell and clogs, but had bennys and not that hard. Easy to learn and do and not many people screwed with you. ( wonder why ??
    Hahahaha . )
  11. abyliks
    abyliks Road Train Member
    3,747
    8,695
    May 2, 2010
    ludlow MA
    Never out of a septic tank, hauled plenty of waste water In tanks and sludge in dump trailers though, absolutely sucks, especially in the winter IMG_2896.jpeg
    Lav-25 and broke down plumber Thank this.
