Seperate BRAKE & Turn signal lights...
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Gambi80, Jan 6, 2011.
  1. Gambi80
    Gambi80 Medium Load Member
    Bought a shiny tail light deal bracket doo-dad from iowa80 the other day. It has 4-4" lights on it, so I could have 2 brake lights and 2 turn signals...seperate from eachother........or so I thought.
    Much to my dismay, I couldn't find a brake only wire and directional only wire(s) on the back end. The brake light is hooked into the signal wire(s) somehow. So now I have 4 brake lights, and 2 signal lights for each side, ######.
    Question is, how far back (well, forward) would I have to go to remedy that? This is on a daycab 378 and came with only 2 tail lights originally. TIA.
  3. Flying Finn
    Flying Finn Heavy Load Member
    972
    556
    Jun 22, 2010
    Ontario, Canada
    It is a 3 prong plug from the wiring harness to the light correct?
    One will be ground
    One will be driving light and brake light
    The last should be the signal.
    CRAP! Forget that ^ it's wrong. There is ground, parking/driving, and turn/brake. Many of those are run that way right from the dash area. You could wire in a unit for a car that is used to convert from that setup to a 7 or 5 pin setup for towing. No reason why it wouldn't work for our purposes as well.... Let me try to find something on the net of what I mean and I'll post back in a few.
  4. Flying Finn
    972
    556
    Jun 22, 2010
    Ontario, Canada
  5. WMGUY
    WMGUY Road Train Member
    1,684
    800
    Jan 1, 2011
    Nine Mile Falls, WA
    go to the 7 way and you should find seperate brake light and turn signal as that is the way the trailers have to be wired
  6. Gambi80
    Gah...I didn't want to have to do some major surgery. I'll finger somethin out I guess.
  7. JohnP3
    JohnP3 Road Train Member
    1,594
    683
    Feb 21, 2010
    Rock Creek B.C. Canada
    What you want to do is run a separate 7 wire to the tail lights, you can just piggy back off the trailer wiring and rewire to how ever you wish. I had a customer that had a sequence set up that he had on a 8 light tail light set up so they blinked like an old FORD.
  8. Brickhauler
    Brickhauler Medium Load Member
    411
    142
    Oct 1, 2008
    Elizabeth CO
    On the firewall under the hood, drivers side down low there is a plastic cover that hides the various harnesses that come out of the cab. You could do some creative rewiring there with the trailer harness and the tractor taillight harness. At least that way you won't be running new wires all the way from one end of the truck to the other. In fact, if you used the wire that normally operated the back up light and hooked it to your new extra brake lights you could probably do it fairly easily and not really hack up the wiring too much. The down side is no more back up light.
  9. Gambi80
    I should have the back up beeper I've got now though...I'd hate to back over a half drunk or half baked laborer at a jobsite some day...
    I think I might try to see what I can find at the trailer plug on the truck...since it's convienently located on the deckplate halfway between the cab and 5th wheel, it should be easy.
  10. truckbiz
    truckbiz Light Load Member
    It's been a long time since I worked on a problem like this, but I think the wireing that causes the brake lite and the stop lite to use the same filiment is in the turn signal switch. On a 378, on the steering column.
    If you can check somehow and see if there is a wire that is hot when the brake lites are on that should tell you. ( no other reason for brake circuit to be with turn curcuit).
  11. Gambi80
    There are 5 wires back there now...park, left turn, right turn, reverse and one that's got nothing. Maybe I'll have to activate the dead one somehow.
    The truck is 10 years old though, I don't think I want to go tearing through the wiring blocks on the firewall and open that can of worms. Got the day off tomorrow, so maybe I'll provide myself with some cheap entertainment thataway.
