Semi truck registered as a motorhome
Discussion in 'Ask An Owner Operator' started by Stroked F550, Dec 16, 2014.
  1. Stroked F550
    Stroked F550 Medium Load Member
    325
    42
    Jan 23, 2008
    somewhere
    Do any of you guys have a semi truck registered as a motor home?
    If so do you ever pull a step deck, lowboy hydraulic dovetail with it for for non commercial purposes. ( i.e. hauling your own property)
    What have been your experiences if so?
  3. Allow Me.
    10,642
    12,101
    May 28, 2009
    Rancho Mirage, Ca.
    Most class 8's registered as a RV have the 5th wheel removed.
    x1Heavy Thanks this.
  4. rollin coal
    rollin coal Road Train Member
    13,083
    25,868
    Mar 29, 2008
    TN
    No but sure sounds like asking for trouble.
  5. Stroked F550
    325
    42
    Jan 23, 2008
    somewhere
    It wouldn't be used for commercial purposes
    x1Heavy and 77fib77 Thank this.
  6. Ridgeline
    22,103
    113,210
    You can't have a rv pulling a commercial trailer for hire. Even if you put Not for Hire on the side, it is still a commercial vehicle.
    You can register your truck as an RV, most of the time it has to have a sink, a toilet and some other things mounted inside the sleeper. But then you are an RV not a truck at that point.
    wifi_guru and x1Heavy Thank this.
  7. Stroked F550
    325
    42
    Jan 23, 2008
    somewhere
    Once the rig is registered as an RV it is no longer a commercial vehicle as it is now a recreational vehicle
    Also my domicile state does not have a registration classification of commercial trailer a trailer is just a trailer doesnt matter if it 10ft long one axle or a 53 ft step deck it has the same registration classification
    I am NOT for hire, I am hauling my own property. There is no compensation involved
    Also it is not a requirement to remove the 5th wheel in order to register it as an RV
    A RV can pull a bumper pull car trailer and flat bed trailer.
    The rig is registered as an RV.... whats the difference with pulling a step deck or lowboy?
    ChevyCam Thanks this.
  8. rollin coal
    13,083
    25,868
    Mar 29, 2008
    TN
    Probably should check with your state. What do you move around recreationally with a lowboy? If you get pulled over you better have a good answer and be ready to go to court.
    wifi_guru Thanks this.
  9. Stroked F550
    325
    42
    Jan 23, 2008
    somewhere
    Tractors, army 6x6 trucks big stuff like that
  10. wore out
    wore out Numbered Classic
    15,319
    184,961
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Trucks that are converted to RV's can get by hauling toys for example race cars, dune buggies, horses but not general live stock. You put livestock, or anything on a low boy and are not for hire than a Farm plate is what you need.
    Deere hunter and wifi_guru Thank this.
  11. DrtyDiesel
    DrtyDiesel Road Train Member
    5,348
    2,598
    Feb 14, 2010
    Jacksonville, FL
    I always wondered about this.
    I always dreamed of having a show truck. Just register it as an RV and drive it around to truck shows. No log book, no worries
    Deere hunter and Big_D409 Thank this.
