Semi trailer tire size
Discussion in 'Ask An Owner Operator' started by Ikamob01, Apr 27, 2022.
  1. Ikamob01
    Ikamob01 Medium Load Member
    314
    195
    Dec 4, 2021
    What tire size do you put in your semi trailer and why do you think is the best...?
    Example...11R22.5
  3. skallagrime
    skallagrime Road Train Member
    3,836
    9,879
    Apr 10, 2012
    Indiana
    Low pro 22.5,
    Price
    Availability
    And low pro because taller rubber (usually more tread) results in more tire scrub in tight turning.
    More than that needs to know your field
    God prefers Diesels and Bean Jr. Thank this.
  4. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,056
    Nov 18, 2014
    Land of local
    Van. Low pro 22.5 that's what most van/reefer run
  5. baha
    baha Road Train Member
    4,137
    2,835
    Jul 25, 2013
    ga
    You need to look at the rolling resistance of any kind of tire at, AMBT, or something like that, just look up truck tire rolling resistance and it will send you to the website?
  6. Big Road Skateboard
    5,687
    29,608
    May 2, 2021
    Availability and fuel efficiency. Lighter tires of a given brand and model will be more fuel efficient. Every tire shop you might need has LP 22.5 of some sort.
  7. Ikamob01
    314
    195
    Dec 4, 2021
    But I'm talking about the first 4 digits... examples 11r or 295 75...etc
  8. skallagrime
    3,836
    9,879
    Apr 10, 2012
    Indiana
    11r means "tall rubber, so none of those
    As for the 275 80r to 295 75r
    80s are .3 % odometer reading different than 75s, bigger difference between new and old tires
    295 vs 285 vs 275... marginal differences to surface contact, this "tire width" and has some bearing on rolling resistance and weight rating, but better off simply specifying one tire in any of those at the best price
  9. Ikamob01
    314
    195
    Dec 4, 2021
    With lo-pros sometimes it is hard to get over some pits to unload.
  10. pavrom
    pavrom Road Train Member
    3,162
    7,247
    Apr 29, 2012
    NE illinois
    ... depending on the application ...you may think of open or closed sidewall as well
  11. skallagrime
    3,836
    9,879
    Apr 10, 2012
    Indiana
    Remember when i asked what your application was? Yeah that matters.
    in ag and hopper bottom you may actually be better served with 11r 24.5
    Big Road Skateboard and Last Call Thank this.
