Within the next 18 months I plan on replacing my 475 ISX with what I'm hoping to be is the Signature 600. I wanted to hear from anybody that has one or had one and what their honest reviews are. The pros and the cons from the real world. Looking to gather insight on performance and maintenance, any known issues, and overall driver happiness. I currently have a 13 speed, 3.55 rears, but thinking about maybe jumping up to an 18. I don't haul very much weight at all, this is more of a treat to myself. I want the power when I want to use it. I've never had an engine with that much power and it's time to have some fun. This will all be tucked under the hood of a 09 W9 so I don't really know if the emissions (DPF only) will take some of the fun out of it.
Seeking reviews on Cummins Signature 600
Discussion in 'Ask An Owner Operator' started by TheLoadOut, Jun 14, 2020.
Why not just turn your current ISX to a 600?? And if you’re not pulling heavy swapping the 13 for an 18 will be a complete waste of money.
feldsforever, Deere hunter and Long FLD Thank this. -
Signature 600 was an early 2000's engine IIRC. If it is it may be a pain to get the DPF to work with it.
TheLoadOut Thanks this. -
The signature may not be able to communicate with the truck gauges. @spsauerland @Goodysnap may know if it can.
TheLoadOut, Vampire, blacklabel and 1 other person Thank this. -
Very good point. The Signature 600 was from prior to multiplexed dashes in the Kenworths IIRC. I think they switched over to multiplexed gauges in around 2006?
Might involve having to replace all the gauges and lights in the dash and an entire re-wire of the dash.TheLoadOut, Vampire and 062 Thank this. -
You running cali op? Keep your engine get cpl off the 600 and do it that way. Keep the 13 and save $$$ for other stuff.TheLoadOut and AModelCat Thank this. -
Vampire and Brettj3876 Thank this. -
So lets use our brains about this.. One swapping to a 18 speed is a waste of money.. Unless you are pulling more then 110k i wouldn't even think of a 18 speed transmission. Buying a Sig 600 to swap into a newer truck is also a waste of money. Upgrade the motor you have when its time to rebuild..
feldsforever, Vampire and TheLoadOut Thank this. -
feldsforever Thanks this.
