Seeking advice on a tractor/dump trailer
Discussion in 'Experienced Truckers' Advice' started by Bigfoot62, Oct 30, 2011.
  1. Bigfoot62
    Bigfoot62 Light Load Member
    92
    29
    Oct 29, 2011
    Louisiana
    Hi folks,
    I'm new to this forum, but not the trucking industry. I've been driving since I was a teenager.
    I'll try to be brief, but I want ya'll to understand my situation. For the past 15 years, I have been out of the trucking business. (I owned and operated a fire protection company) My previous dump trucks were bobtails, but I'm considering buying a T/T dump rig. (triple axle end dump for hauling rock and sand) There's work in my area, and this is a business that I've been in before, so I'm not debating whether or not I can "make it" with the rig. The math works out, so I'm satisfied with that. I just need your advice on specifics. I want you to tell me what you would look for, or avoid, in a tractor/trailer dump combo. For the forseeable future, I'll be driving this myself. I want it to be dependable and nice, but I'm not looking to buy new. Good, clean used stuff works for me. But, since I'm looking for used equipment, I know I can't be as picky. So, please, in all your responses, let's have basically a "this will work" or a "stay away from this" kind of reply.
    I'm looking at local hauling, 300-400 miles per day max. I want to be able to carry pretty much anything. (rock, sand, asphalt, etc) Day cab is my choice, but I realize that I might find a deal on a sleeper cab truck. I know there will be some long days, but I plan to be home every night.
    I'm not trying to "open a can of worms" here or pick any fights. We ALL have our preferences. I have a pretty good idea of what I'm looking for, but I want the opinions of people that have been there and done that, those of you who have way more experience that I.
    Tractor:
    Pete or KW is my pick, but what other trucks might be considered?
    I'm thinking big Cat, but what other engine options would work well? Also, what hp range to consider? (remember, this is a dump truck and it's got to have lots of "grunt")
    Transmission and gear ratio?
    Wet kit. Any brands that are "bulletproof" or any brands to "avoid like the plague?"
    Trailer: triple axle aluminum end dump.
    I like the Travis and Mate brand trailers. Any others that I should keep my eyes open for?
    Frameless, half-frame, etc,. Advantages/disadvantages of each.
    Thanks in advance.
  3. Pedigreed Bulldog
    7,737
    14,421
    May 7, 2011
    For dump work, you can't beat a Mack...if it's got a Mack drive train. Mack engine, Mack transmission, Mack rears. If it doesn't have a Mack transmission or rears, when you turn off the pavement and into the job site, you're no better off than if you were driving any other truck.
    You can't buy a new truck with a Cat engine...they called it quits with the latest round of emissions regs. Not only that, but being paid by the ton as in dump work, the heavier the truck, the less you can haul. Big Cats are heavy. One other thing to consider, big engines require beefy transmissions and rear ends, too...all adding additional weight. Big HP & torque through lightweight transmissions and rear ends = broken parts & pieces. Most companies will spec a 12-13L engine. Make up for the smaller engine with gearing...spec a transmission with low low gears to get you rolling, and "slower" rear gears.
    My truck has an E7-460 Mack engine, Mack 2180B 18 speed transmission, and 4.17 Mack rears...and I run circles around company trucks and even other O/O's any time the ground gets soft. I carry a chain in my side box, but 9 times out of 10 that I need it, it is to pull out a stuck Peterbilt. I like the 18 speed, because it's got a low low gear to get moving, small steps between the gears to work my way up to speed, and a double overdrive to keep my RPM's reasonable on the highway.
    As for wet kits, around here most use either Chelsea or Muncie PTO's and pumps. Tanks are tanks, and lines are lines...get them anywhere tanks and lines are available...might even find an old fuel tank and convert it pretty cheap.
    For trailers, all I've ever pulled is 39' frameless. Lightweight, and do the job I've needed them to do just fine. Just have to be careful in soft ground, because you're putting a lot of weight on that 1 axle...so it has a tendency to sink. If you dump off, and you aren't getting great traction with your drives, and the trailer axle is in a divot, you may not be able to pull forward...but if that happens, just lower the bed a little, set your tractor brakes, release the trailer brakes, and use the hydraulics to pull the trailer forward out of the low spot. I have never seen a frameless trailer used to haul asphalt. When dumping, the tailgate height lowers as the bed raises...which isn't good if you're dumping into a spreader.
    I haven't seen 1/4 frame trailers longer than 35'...which would require a 3rd axle to run 80,000 (unless you can move enough weight onto your steers, or run exclusively in a state which has different weight limits AND you stay off the interstates). Nice thing about the 1/4 frame is they keep all wheels on the ground, so you're less likely to sink in while dumping. That and since the tailgate height remains constant, you can use it for asphalt.
    With either the frameless or the 1/4 frame, if you are empty and get stuck, you can use the trailer to "worm" your way out....set the tractor brakes & pull the trailer toward the truck, then set the trailer brakes and push the truck forward. Repeat as necessary.
    Frame trailers are a little heavier. If they tip, they generally pull the truck over with them. If you get stuck, you're stuck and need someone else to pull you out. I don't care for them much...
    Bigfoot62 Thanks this.
  4. Allow Me.
    10,642
    12,099
    May 28, 2009
    Rancho Mirage, Ca.
    I'll just add sleeper VS day cab. Sleeper is heavier, therefore, less payload. Plus a lot of hot plants won't accomidate sleepers (condos). Food for thought.
  5. SL3406
    SL3406 Medium Load Member
    550
    1,482
    Jan 10, 2011
    Oklahoma
    What to buy really comes down to personal preference. I own a day cab Pete with a 550 Cat 18 speed and 3.70 rears on air trac suspension. I recommend the 18 speed it works really well for the work we do. I'm not real familiar with Louisiana weight laws, but if you're limited to 80k gross then 40k pound rears and a single frame is all you will need. Anything heavier just adds unneeded weight to the truck.
    If you want to haul asphalt then you're limited to either a 1/4 frame or a full frame trailer. I pull a 26' 1/4 frame Travis. It works really well and weighs about 10,500 with aluminum wheels. The best bang for the buck in a 1/4 frame trailer IMHO is a Hilbilt brand trailer which is built in Benton Arkansas. Their only down side is they're steel and weigh about 12,500 although they're about $10,000 cheaper than a Travis trailer.
    A word or warning: Nearly all of the 1/4 frame and full frame trailers I have seen turn over take the tractor over with them so be very careful about where you choose to dump.
  6. Bigfoot62
    92
    29
    Oct 29, 2011
    Louisiana
    I'll look into the Mack. Just don't know anyone that's running a Mack T/T dump rig locally.
    Not looking to buy new. I just can't justify it. Probably looking for a 3-5 year old that's been taken care of. I'll even buy older, if it's in really good condition.
    Good info on the trailer. That helps a bunch. I don't know for sure if I'll carry asphalt, but I would like to have that option.
    Thanks for all the info. I really appreciate you taking the time to explain.
  7. Bigfoot62
    92
    29
    Oct 29, 2011
    Louisiana
    Exactly my thoughts. I don't forsee anything that I would need the sleeper for anyway. There just seems to be a lot more tractors available that have a sleeper cab than not.
    Just spent a couple of hours talking to one of my cousins today. He has two tractors, a Pete and a KW. Both have flattop sleepers. Not that they are needed, he just "likes the way they look." Go figure. :biggrin_25513:
  8. Bigfoot62
    92
    29
    Oct 29, 2011
    Louisiana
    Will look at the Hilbilt. I really want a 3rd axle. Here, in Louisiana, a "Gravel Truck" can gross 88,000 with a 3rd axle trailer. Might as well get paid for the 4 extra tons.
  9. Kw900a
    Kw900a Light Load Member
    55
    13
    Sep 29, 2011
    mifflinburg pa
    most guys round here run macks for offroad use like farmers and gas drillers. i run a w900 with a ravens spread axle dump trailer the w900 has a 500 cummings with a 13 speed. i usually pull on scale with just one tank full and the dump anywhere between 29000-34000. we only fill one tank because we don't use truck for more than coal and grain. its a heavy truck. now pulling wise itll pull like a raped ape. i know alot of people told me that petes r lighter than kw's. i ran a ch700 460 mack engine with a 8 speed that thing ran an was an alright off road/on road truck so maybe you could check into a mack. but most off road/ on road guys run macks round here. theres couple outfits running petes but i think the dump on pavement. im sure this probably doesn't help n you probably just wasted your time reading this i thought maybe i could give you some insight of what i see mostly running round here
  10. Gambi80
    Gambi80 Medium Load Member
    Full lockers, 13/18sp, if it's a Pete get air-trac, 3:55-3:90 ratio (don't know the speed limits in LA)...otherwise it's the same drivetrain just packaged a little differently. The 'cherry' daycabs in the '00-'03,4,5 range are getting more scarce by the minute.
    Can't help you on the trailers much. But if you plan on hauling asphalt and having an aluminum trailer with a liner, the asphalt liners are about twice the price of a regular liner. Most liners are rated for 140*, so if you dump 350* asphalt on it you'll end up with a giant turd.
    There isn't one do-all trailer...buy (and don't be afraid to spend for something decent) one that'll cover what you'll mainly do. After a while, add another to do the rest.
  11. Bigfoot62
    92
    29
    Oct 29, 2011
    Louisiana
    Thanks to all who offered advice.
    I pulled the trigger today. Here's what I got:
    Tractor is a 1995 KW T800 conventional w/sleeper. Didn't need the sleeper, but "beggars can't be choosers." Yes, it's a '95 and she's got a bunch of miles, but has been well cared for and is in great shape. CAT 3176C engine, Fuller 8LL transmission, 3.70 rears.
    Trailer is a 2001 Clement tri-axle steel tub frameless end dump. 26 cubic yard capacity. Brand new lift cylinder, electric tarp, and new rock liner. Used, but not abused.
    The trailer dealer will install the wet kit, as well as the truck-mounted controls for the tailgate, tarp, and tag axle. They are supposed to start on the truck Monday. The new cylinder was ordered today.
    I promise to post pictures as soon as I get it all done.
