Secondary air pressure keeps dropping/fan turns kn
Discussion in 'Trucks [ Eighteen Wheelers ]' started by mhlvc, Jun 2, 2020.
  1. mhlvc
    mhlvc Light Load Member
    111
    43
    May 2, 2020
    2016 579 Cummins ISX15
    Its 90+f and coolant gets hot really quick, and all of the sudden my secondary air pressure keeps dropping and engine fan keeps going on all the time.
    What could be the issue? Any ideas?
    Radiator?
    D.Tibbitt Thanks this.
  3. D.Tibbitt
    140,936
    Idk about the air pressure but the fan coming on and off is normal on a hot day with the ac running
    magoo68 Thanks this.
  4. mhlvc
    111
    43
    May 2, 2020
    Now even when I idle more than 5min or so the secondary air pressure goes down and engine fan turns on.
    WTF is happening. I had this issue 2 weeks back and Kenworth/Peterbilt shops couldnt get it to act up so they didnt find out what the problem is
  5. mhlvc
    111
    43
    May 2, 2020
    I guessed so but man even going on a straight highway with a little hill - fan turns on. It wouldnt be an issue if my secondary air pressure didnt act up as. I have no idea what to do. Im at a PETRO right now but not sure if taking it in the shop here would do me and good. It is acting up currently so maybe they could find out what the issue is?
  6. magoo68
    magoo68 Road Train Member
    3,393
    5,385
    Jun 11, 2011
    st malo mb canada
    Anyone look at fan hub to see if it’s leaking.
    Rideandrepair and D.Tibbitt Thank this.
  7. D.Tibbitt
    140,936
    How much psi are u losing ? i wouldnt worry about the fan coming on and off. That is normal . with ac on and it hot outside its going to repeadtly come on every minute or so
  8. mhlvc
    111
    43
    May 2, 2020
    I literally just keeps going down, so a lot. It mostly happens when downshifting, but now even when I idle it happens it seems.
    I did put new air lines, but even when not hooked up to a trailer it happens. Could it be anything computer related or electrical/fuses/relays? Peterbilt did computer/engine software updates so idk
  9. SmallPackage
    5,278
    16,463
    Dec 20, 2019
    Marion Texas
    Sounds like the fan hub or the solenoid to control the fan. Or the air line between the solenoid and hub is leaking.
    Rideandrepair, magoo68 and D.Tibbitt Thank this.
  10. mhlvc
    111
    43
    May 2, 2020
    Will get that checked out. How safe am I to drive through the night and tomorrow where Ill take to to a local shop? Temps did drop down to 60s
  11. BoxCarKidd
    BoxCarKidd Road Train Member
    4,418
    6,431
    Aug 26, 2014
    How low does the air pressure go before the fan kicks on? How low does it go at the most?
    If it does it in the parking lot maybe try this. Turn the key off to stop the engine and noise. Turn it back to the on position. Then get out and try to find an air leak.
    If the engine is never over 220 for a short time and air pressure under 90 I would rock on. Better to fix it if possible. If the fan hub is leaking air and is air disenguaged cap off the line somehow and get home.
    Rideandrepair, mhlvc and SmallPackage Thank this.
