Looking for some thoughts on this, 500 hours on tripac evolution, apu alternator sending 16 volts and cooked my year old batteries, I replaced them and the alternator was tested and replaced under warranty. Last night I'm watching TV and my xantrex inverter starts screaming, I checked and showed 16 volts shut off the apu (it wasn't throwing a code). Verified at the batteries with multimeter, yup vr toasted again.
Grounds seem to check out alright, truck alternator runs 13.8-14.0, all fuses and sense wire are ok.
Related issue, I have hydraulic doors on my trailer, the pump pulls power hard enough that the apu would sense low voltage and start. It does not do that anymore.
I do run a hard load on the apu for short periods 1300 watt max induction hot plate, about 1 minute then dropping to about 450 watts for a few minutes. Apu is 65 amp, 14.5 volt max.
Is it possible to burn out the vr with too high of a load, and would that be enough to do it
Second voltage regulator burned out
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Rounded_nut, Aug 4, 2019.
Advance Auto Parts - Down for MaintenanceRounded_nut Thanks this. -
I did little modification on my Tripac. I cut the *Belt Tensioner 92-9046* and drilled new hole at end. Also bought a shorter belt from napa. Now after adjusting the belt alternator stays away from muffler. It stays exactly in the middle between engine and muffler. I run the unit few hours and measured temperature of alternator. It was running ~25 degrees cooler... No more burned voltage regulators.
arn12 and shatteredsquare Thank this. -
I'm trying to make the same modification that you did. How much shorter you made the 92-9046 thermo king belt tensioner? Also if you can give me the part number for the new belt. Thanks -
i cut about 2-2.5 inches... positioned alternator between engine and muffler, made markibg and cut it.
i dont remember bel number, the truck is sold now. i put old belt on it. Cut portion of belt. Then took that cut belt to Napa. The guy measured it and gave correct belt...arn12 Thanks this. -
I use a NAPA 25060490 belt. It’s a 49” belt and puts the adjuster about midway in the slide. You would have to measure at the shortest point of the slide to see if a 25060480 will fit.
shatteredsquare and arn12 Thank this.
