Hi. How to remove/fix the red light on the dash on 2012 Cascadia? The red light stays on all the time. And sound warning when start moving. I fasten the belt all the time.
Seatbelt red light
Discussion in 'Freightliner Forum' started by marat80, Jul 29, 2017.
Page 1 of 3
They don't call em a crashcadia for nothing, buckle up!
Have a cooler in the passenger seat? Maybe it senses that and thinks a person is there not buckled in. I have had quite a few vehicles give me a warning light/tone when someone is sitting over there but not buckled up.Bean Jr. and driverdriver Thank this. -
If your seatbelt has a sensor in the belt receptacle, in theory you can take the two wires and splice them together completing the circuit and making it go off. The seatbelt typically has some cheap plastic piece that moves up and down inside to complete the contact, and when the plastic gets worn down, it no longer completes it and the buzzer goes off. Those two wires should be on the outside of the seatbelt receptacle coming from the floor.
marat80 Thanks this. -
Just trace from the seatbelt receptacle down and find the sensor. Where the two wires are, cut and splice them to each other completing the circuit, telling the truck the seatbelt is fastened. The seatbelt will still work fine and you won't go crazy.
Not sure about Freightliner, but their former 4-wheeler division (a.k.a. Jeep...now owned by Tony) has some sort of sensor at the spool end. My MIL's Jeep dings when she is in the passenger seat without it on, but as soon as she pulls the belt out of the wall 6 inches...it stops, and thinks she has it on, she doesn't have to latch it.
Dullboy859 Thanks this.
Page 1 of 3
