SCR Performance low, engine will derate IN..
Discussion in 'Volvo Forum' started by AlexD13, Aug 23, 2017.
  1. Voyser11
    Voyser11 Bobtail Member
    Dec 29, 2018
    I did for 12 hours and got all sorts of codes including SCR System Failure
    KB3MMX Thanks this.
  3. QUALITYTRUCK
    1,801
    1,762
    Jun 14, 2009
    romulus,mi
    Not a new revelation, but probably worth repeating again.Idling is the worst thing for aftertreatment.
    KB3MMX Thanks this.
  4. Truckers Report Jobs
  5. nasriza
    nasriza Road Train Member
    2,397
    2,070
    Feb 1, 2013
    Chicago, IL
    got to start looking at what the faults are from
  6. MOGLAR
    MOGLAR Heavy Load Member
    743
    518
    Jun 19, 2013
    Kansas City , MO
    On August 1, 2018, Cummins initiated a recall of the Selective Catalytic Reduction (SCR) unit catalysts in their 2010 to 2015 model year medium and heavy-duty engines. This recall affects over 500,000 heavy-duty vehicles nationwide. Customer letters for the first phase of the recall were sent to vehicle owners by Cummins starting August 1. Vehicles are to be brought to a Cummins certified service location for replacement catalysts and/or software upgrades. For assistance, including locating your nearest Cummins certified service location or determining whether your engine is covered by the recall, please contact Cummins Care on the web at https://care.cummins.com or call Cummins at 1-800-CUMMINS (1-800-286-6467).
    � Cummins will reimburse cost of previously replaced catalyst.
    � California Department of Motor Vehicles may require the completion of emission campaign repairs prior to vehicle registration renewal.
    � Cummins will phase-in recalls over time due to the large number of engine families involved. Some recalls will take effect in 2019 as
    shown in the table below. The table will be updated, as new engine families are included in the recall campaign.
    � For 2010-2012 model year ISX 15 Engine Families ACEXH0912XAP, BCEXH0912XAP, and CCEXH0912XAP, SCR replacement will occur
    when the SCR catalyst fails (triggers applicable engine lights/fault codes) within useful life beginning Aug. 1, 2018. Customer letters for
    these three engine families only will not be mailed out.
    � If your engine family is not listed below and you replaced your catalyst or if you have additional questions, please contact the ARB
    helpline at 1-800-242-4450.
    ► View List of Affected Engine Family Names/Numbers
    KB3MMX and Newto Trucking Thank this.
  7. KB3MMX
    KB3MMX Road Train Member
    3,069
    2,588
    Dec 29, 2014
    Orrstown, PA
    Repeat ..
    Repeat ...
    Lol
    This is why an APU is so important on an emissions truck
    QUALITYTRUCK Thanks this.
  8. shreemike
    shreemike Bobtail Member
    12
    I got 2 times Parked regen in 2 days. It's time it took over 100 mins and regen did not complete. I stopped. Check sign remained and spn 4094 fmi 18 also remained.
    Any idea?
  9. nasriza
    2,397
    2,070
    Feb 1, 2013
    Chicago, IL
    Possible something going on with fuel system for regen or engine is putting out to much nox or maybe even a bad nox sensor not very likely I. Last one being that bad sensor will kit cause long regens
  10. Celina
    Celina Bobtail Member
    19
    8
    Feb 9, 2020
    How often do you replace them.
  11. Celina
    19
    8
    Feb 9, 2020
    Hi I have got the code 5655 and they have replace a lot of parts related with the efficiency of the SCR
    The filter is new also a dossier valve and a bunch of harness
    Haven’t replaced the Knox sensors
    Any ideas or recommendations
  12. AlexD13
    AlexD13 Light Load Member
    298
    85
    Jun 13, 2016
    I was in your position, then changed. NOX Sensors and things worked
    KB3MMX Thanks this.
