SCR (Diesel exhaust fluid) Equipment on Highway trucks.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by farmerleach, Nov 9, 2010.
  1. farmerleach
    farmerleach Light Load Member
    80
    28
    Dec 1, 2009
    I am just wondering if any one has run a truck with the SCR equipment. I have heard better power and fuel economy. I am looking at a new truck and just looking for some information. I have heard good things in the ag side of things. Keeping the Urea around wouldn't be a problem for me as my farm equipment is going to need the stuff here pretty quick.
  3. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    SCR is new system and it is not trouble free. Some drops of diesel in carbomide tank kill SCR pump, sometimes SCR unit looses pressure, sometimes there are heaters issues.
    and all the parts are expencive.
    any SCR fault causes engine derate and speed limiting.
    think twice before you purchase SCR equiped truck
  4. 98989
    98989 Road Train Member
    5,990
    6,740
    Sep 14, 2008
    i dont drive similar truck but we have here scr since 2005 and it is work just fine.....
    but def can freeze on -11C =~-12F
    You should also pay attention to the quality of the ad blue-DEF
    because the less quality additives are often making problems ,,,,,,(crystallization, damage to pumps and.....)
    usually those truck are about 600-700lbs weight more.....
    fuel consumption is at least here lower than on euro 3 engines .......also they are a bit stronger
  5. Sportster2000
    Sportster2000 Road Train Member
    1,480
    886
    Jan 5, 2008
    Indiana
    Throttle response is better. You have to figure in DEF consumption along with fuel to get proper fuel consumtion because what you are not spending on fuel you might be spending on DEF.
  6. trucker2009
    trucker2009 Bobtail Member
    10
    Sep 18, 2009
    we have new volvos 2011 vn670 d13 engines with scr
    we averaging 6.5m/g 35k dry van going west from chicago .
    and about 60m/g on urea .
    our fleet 15 trucks two months so far no problems.
  7. dwayne
    dwayne Medium Load Member
    324
    165
    Apr 19, 2008
    Wonder how long it will be before there are stories floating around about drivers filling those tanks with things other than DEF.
  8. JohnP3
    JohnP3 Road Train Member
    1,594
    683
    Feb 21, 2010
    Rock Creek B.C. Canada
    Any driver that sabotages the system will not be driving very long.
    There is a group of Videos on the Detroit site from trucking companies that used the trucks with the urea, they are very interesting not a bunch of taking heads that are full of BS, Just company executives talking about what they found and what the drivers thought of them, fuel mileage and costs. I watched them a while back, very interesting. I would Imagine Cummins has the same type site.
    There is an EPA sticker on all new engines with the number of MM3 fuel burnt to make Max HP, it is a good idea to find that number for the different engines, the International has no urea.
    Just a thought!
  9. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    first year we operated SCR Volvo with D13 we had no problem, better fuel milage, better engine responce....
    But later we got urea injector leaking, low urea pressure, crystalisation, faulty hose heaters, coolant valves... and some problems block scr system and engine power derate actuates. Truck slooooly runs in limp home mode to change some SCR parts...
  10. V8Lenny
    V8Lenny Road Train Member
    1,016
    130
    Aug 3, 2008
    Europe
    You ca fill it with distilled water but then tha cel light will go on and engine derates because nox sensors see that something is wrong. Some drivers used tap water with earlier euro engines that didn't derate, minerals blocked the cat, new cat from 5000 to 10000 euros..
    Here is the solution: http://www.ecuflash.co.uk/Adblueremoval.aspx
  11. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    It is not legal. I did D13A Euro-III reflashing. SCR goes on working, but if SCR fails, no HP derate. Pulling out fuse in battery box disbles SCR. But if you drive truck with SCR disabled urea injector fails with overheating and in Europe cops may inspect truck and do emission test.
