Scania v8 better than cat engines?
Discussion in 'Peterbilt Forum' started by Ahmad Abdel, Jan 13, 2021.
  1. Ahmad Abdel
    Ahmad Abdel Bobtail Member
    9
    7
    Jan 13, 2021
    why do european semi truck engines have more hp and torque than cat or cummins engines?
  3. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,056
    Nov 18, 2014
    Land of local
    16.4L for one but a v8 will make its power higher in the rpm range compared to an inline 6. Pretty much all I-6 will have a longer stroke than bore meaning slower to rev but more torque down low. Most V8s will have an over square bore meaning same stroke and bore (or close to it anyways) the v8s are rev happy
  4. jason6541
    jason6541 Road Train Member
    2,425
    5,365
    Mar 5, 2012
    Omaha, NE
    Inline engines are smoother and last longer.
    As for why the V8 makes more power from factory in Europe not sure.
    You can get a CAT or Cummins up over 800 HP and well over 2300 ft lbs of torque.
    Warranty is a big part why the engines were never turned loose from the factory that way. Another is the market here in NA
    Most drivers would use and abuse power like that.
  5. Trucking in Tennessee
    Trucking in Tennessee Road Train Member
    3,740
    5,738
    Mar 19, 2018
    Nashville
    Trucker61016 Thanks this.
  6. Ahmad Abdel
    9
    7
    Jan 13, 2021
  7. Tb0n3
    Tb0n3 Road Train Member
    4,278
    8,194
    Oct 5, 2012
    Earth
    Yeah. Six cylinders are perfectly balanced without needing excessive counterweights. First and second harmonics are under control so it's just smoother.
    God prefers Diesels Thanks this.
  8. Ahmad Abdel
    9
    7
    Jan 13, 2021
    the scania 770 engine has 2720ft lbs of torque and 770 hp, what american\australian trucks beats its torque or hp?
    Bean Jr. and alds Thank this.
  9. Tb0n3
    4,278
    8,194
    Oct 5, 2012
    Earth
    Probably larger engines. You do understand that V8s have 2 more cylinders than an I6, right?
  10. AModelCat
    154,213
    Put an aftermarket tune in an engine. Problem solved.
  11. Trucking in Tennessee
    3,740
    5,738
    Mar 19, 2018
    Nashville
    Why do you need all that? This is why. We don't do this here.
    singlescrewshaker Thanks this.
