Scania 124 470 trouble....
Discussion in 'Trucks [ Eighteen Wheelers ]' started by ah fai, Aug 21, 2012.
  1. ah fai
    ah fai Light Load Member
    178
    Hello everybody, i am from MALAYSIA and new to this forum, my truck get in trouble, hope can get some help....
    2001 years SCANIA 124, 470HP.. poor in engine power, when i press the accelerator padel, the RPM going up very slowly...
    I already overhaul the engine and replace the charge air pressure sensor, fuel pressure sensor and turbo...but still the same. Try to send it to scania dealer and get the unit injector service and diagnos, same result
    thanks..
    :biggrin_2552:
  3. Scania man
    Scania man Road Train Member
    2,199
    483
    Jul 1, 2011
    Saskatchewan
    I was never a fan of the 470 or 480 for that matter, Pablo ua or v8 Lenny or 98989 ,all those know those engines. Best of luck!
  4. dieselroarmt875b
    dieselroarmt875b Medium Load Member
    315
    58
    Aug 26, 2008
    YOURAPEEIN
    the injection system used on this scanias is very capricious,you should check all valves ,o- rings,test for air sucking
  5. 98989
    98989 Road Train Member
    5,990
    6,740
    Sep 14, 2008
    is there everything ok with turbocompound? as much i know they were not offered at your market maybe your service have no experience with it .....they usually need service at 600 000km maybe it cuts your power
  6. Scania man
    2,199
    483
    Jul 1, 2011
    Saskatchewan
    Turbocompound is why I never bought this truck,
  7. ah fai
    178
    hello, everybody ...thanks for your reply..
    Ya, my scania 124, 470 engine with turbocompound, you are right man... the local dealer, they dont even check the turbocompound and i dont think they can take care for that. this type of truck is very less in my country.
    I have no idea for the turbocompound, should i replace it? it is possible with used unit? and how to troubleshoot or service?
    Today i get my truck for fuel pressure test, connect the guage to fuel filter housing and show 250psi at 700rpm.
    thanks,
  8. 98989
    5,990
    6,740
    Sep 14, 2008
    you should think about that before you bought it with different engine than is available on your market...
    repair on turbocompound in europe cost 3000€
    no replace they usually need bearings or sometimes other things but not replace
    engine 470hp is quite strong if working normally it can overperform some 500hp engines
    did you check for fault codes? is there any?
    there is one scania r470 here converted to 420 (in europe we had 420 as euro2 later as euro3 as pde -same as on your market and after as euro3 with hpi injection (same as used on 470) ....also we had 440 with 4nox for austria with turbocompound this was very problematic one
  9. Scania man
    2,199
    483
    Jul 1, 2011
    Saskatchewan
    I've heard some horror stories about turbecompound, the bearing breaking and being sucked into the engine
  10. Worthken
    Worthken Light Load Member
    265
    83
    Jun 2, 2012
    Delmas South Africa
    Can anyone explain turbocompound?, I'm not familliar with the term. Just for interrest sake. We have the 470 motors over here. In the begining they had alot of crank issues, but they were sorted out. As far as I know the 470's perform very well with fuel.
  11. 98989
    5,990
    6,740
    Sep 14, 2008
    they are basic dc12 engine with that turbocompound another turbo behind main turbo
    but that second turbo dont have inlet side but only exhaust
    that second turbine use energy of exhaust gasses and transform them in rotational power and put them on flywheel as additional "free" power
    they consist inside of power turbine and on other side gears hydaulic clutch, in our conditions here turbocompound engine get 1L lower fuel consmption than 420 in average , only case when it does not have fuel benefits are when you are empty on highway
    they are quite "slow" you need about one or two gearchanges before it would start to work
    Worthken and Scania man Thank this.
