Scaling by axle at the shipper. Where do you line up your axles on the scale?
Discussion in 'Questions From New Drivers' started by DocWatson, Aug 31, 2014.
  1. DocWatson
    DocWatson Road Train Member
    1,263
    1,006
    Jan 21, 2010
    Jersey shore
    This is a question I should have asked a long time ago.
    When scaling at a shipper on their scale and you want the most accurate recording of each of your axle's weights, where do you position your tires/axles on the scale?
    Considering that we are driving up on a flat surface scale (not one of those ramps), where do you get the most accurate and true reading?
    For example, you drive your steers up onto the scale. Do you measure the weight just as the steers roll on to the scale or do you drive them a few feet forward on the scale whereby the beginning of the scale is exactly equidistant between the drives and steers? Same thing with the drive wheels. How far onto the scale do you drive your drive axles before you record the weight?
    I've been recording my weights for the steers when I see that the beginning of the scale is exactly equally distant between the steers and drives. Not sure if this is right. For the drive axles I have been driving them on to the scale when they are about 4 feet onto the scale.
    Something to consider when you want an accurate reading and the nearest CAT scale is far away.
  3. double yellow
    5,946
    10,066
    Aug 28, 2011
    State of Jefferson
    I would think the most accurate way to weigh on a raised platform is to pull almost all the way on the scale but stop just before trailer tires roll onto scale. Record weight A. Then pull all the way on, record weight B. Then just barely pull the steers off the scale. Record weight C.
    B - C = steers
    B - A = trailer
    A - (B - C) = drives
    DocWatson Thanks this.
  4. SlowPoke44magnum
    SlowPoke44magnum Medium Load Member
    407
    519
    May 3, 2009
    Walbridge,Ohio
    I would pull onto the scales until my drives were at the edge of the scales but not on them, record that weight, that's your steer weight. Then pull up until the trailer axles are almost on the scales but not on, then record that weight. Subtract the steer weight from the steer/drive axle combo weight to get your drive weight. Then pull up far enough so only your trailer axles are on the scales, center them on the scale if space allows, record that, now you have your axle weights. I've done it this way for years and never had a problem. If my axle or gross weights were very close to legal limit I would still weigh at a CAT scale as one never knows for sure how accurate shippers scales are.
  5. DocWatson
    1,263
    1,006
    Jan 21, 2010
    Jersey shore
    Interesting. Not the way I've been doing it but I think I'll give this a try.
    I've seen other drivers doing it different ways and I've been trying to figure out which way will be the most accurate. Today, when picking up a Georgia Pacific load and scaling it there, I placed my axle in different locations on the scale and then averaged the difference in weight that came up. The difference wasn't that great but it was still slightly different. I did that for both steers and drives. Then of course once the trailer was on there with the other axles I had the gross.
    I remember being at a certain shipper and the yard jockey had me take the axle weights at the point that my axle just barely went over onto the scale. Another new way that I hadn't seen before that.
    I'm just looking for the most accurate reading until I can get to a legitimate CAT scale. I would like to feel that I'm legal until I can get to the CAT.
  6. MsJamie
    MsJamie Road Train Member
    The most accurate *should* be in the center of the platform. That said, a certified scale *should* be accurate regardless of placement.
    Also, be sure that you don't have any braking going on across the edge of the scale. Holding the service brake pedal while weighing part of your truck can change the indicated weight by a considerable amount. If weighing just the steers, only use trailer brakes. Steers + drives? Only tractor OR trailer brakes.
    On a CAT scale (or any scale that weighs axles independently), I only set my trailer brakes.
  7. snowwy
    snowwy Road Train Member
    20,527
    13,262
    Jul 6, 2009
    i think of it like this. 12.4 + 34 = 46.4. as long as the truck don't weigh over 46.4 i'm golden. anything over that mark and the drives are too heavy. but we've got gauges to see that before we even roll.
    then scale tandems, make sure they aren't over 34.
    doesn't matter at what position on the scale you are. watch the sign if they got one. once that axle hits. that's what it reads untill something changes like rolling off the other side. or adding an axle.
    if you happen to be on a scale with a ramp. you defenitly want to pull as far forward as you can without the next axle rolling on.
    with full tanks my steers weight 12.4 doesn't matter how heavy the drives are or if there's a trailer at all. my steers weigh the same. unless i move the 5th wheel back. but that's in a FL. not all trucks work that way.
  8. Starboyjim
    Starboyjim Road Train Member
    2,039
    1,424
    Dec 10, 2011
    Weed, CA
    Snowwy, is your truck licensed for 80K? Isn't 12,400 about 400 over? Or do you have the heavy tires and 13,200 steer rating?
  9. snowwy
    20,527
    13,262
    Jul 6, 2009
    your steer rating is whatever your tires are rated for. and steers are generally rated for 6,175 lbs. X 2 = 12,350 lbs.
    there's other accomodations that can make steers haul heavier. but for the basic operations. that's the rule.
  10. STexan
    STexan Road Train Member
    14,963
    29,153
    Oct 3, 2011
    Longview, TX
    My typical way was to roll all on and get a gross (all axles) (if that's not good then the rest of the exercise may be a waste of time), then roll the steers off there platform then note weight, then pull off leaving only the trailer on and extrapolate the numbers. This keeps as much of the truck near the platform in case of slight grades on/off the platform that can drastically affect weights in some extreme cases where scales are ONLY intended to get gross weights.
  11. SunnyRoadTrucker
    SunnyRoadTrucker Bobtail Member
    38
    15
    Sep 1, 2014
    Elk Grove Village. IL
    I respect your opinion...but it doesnt matter how close or far your drives and trailer tandem to the scale.
    Weight wount change if you bring the drives close or far to scale.
