What if a weight station is closed and you end up scaleing yourself there and you are overweight. But there's a state patrol/ dot officer there can he still give you a ticket even if the scale said it was closed ?
Scaling at a weigh station while it is closed?
Discussion in 'Experienced Truckers' Advice' started by Juan1998, Mar 6, 2024.
Page 1 of 8
snowmantrucking101 and Coolbreezin Thank this.
Bout the only places a DoT officer cant screw with your rig are on orivate property or inside your garage. And even thats dubious nowadays.gentleroger and Juan1998 Thank this. -
the important question is this - why would you even pull into a closed coop?
You go to a cat scale and get weighed, not at the coop.homeskillet, expedite_it, firemedic2816 and 14 others Thank this. -
hunts2much, Accidental Trucker, Dennixx and 22 others Thank this.
Id still be leery of knowingly going in overweight though.gentleroger, Flat Earth Trucker and Juan1998 Thank this. -
I had pulled in an open scale one day, unfortunately I was the last one in when they closest them. Right after I passed the scale plate, it was a green light. I pulled of to the side right after to used the Porto potty. No one else was inside the scale facility. I went in did my business and when I walked back to the truck, the LEO was there and said, “Can you please go back in the scale to check your weight, I had walked away for a second” he said to me. So I did what he said, well guess what, I was 1500 lbs over on the rear tandem. Long story short, I adjusted the weight, and received NO citation, only because there was a shift change and the new shift didn’t right up because he said the prior shift should’ve done it. My point is, YES, they can’t right you up even if there closed.
Feedman and Diesel Dave Thank this.
Page 1 of 8
