scale ticket
Discussion in 'Questions From New Drivers' started by 4noReason, Jun 6, 2013.
  1. 4noReason
    4noReason Road Train Member
    2,375
    731
    Nov 29, 2012
    I got a 50$ ticket for being over on my drives. Dot says no points and not on record? How? Should I contest it with my drivers lega plan
  3. Casual Trucker
    Casual Trucker Medium Load Member
    495
    326
    Sep 7, 2012
    depending on your state and from the new regulation that they have now not only you will have the ticket posted to your record but the company you drive for will have that ticket too but you are the one who is going to pay the fine if you think that you have to consent or Not you really don't have that option unless the scale that weighed your truck was out of service you are here by guilty as charged Mr. Chicken Hauler
    Clikty Click ....COURT ADJOURNED
  4. andre
    andre Medium Load Member
    341
    172
    Feb 10, 2008
    Jacksonville, FL
    overweight tickets go to the company that owns the truck. If you are an O/O, you pay. It also doesn't go on your driver's license, since I assume you got it going over a scale, and not on the side of the road at a portable scale after being pulled over. If you get pulled over and do a portable scale check, they do go on your license (a DOT guy at a scale told this). I don't know how they handle the CSA points though. I've gotten plenty of overweight tickets hauling dry bulk cement and they aren't on my CSA, so that's something.
    As with many things, DOT has alot of leeway to handle each situation the way they feel is best. Whatever you do, don't go into their office cursing.
  5. Ranger Bob
    Ranger Bob Light Load Member
    245
    210
    Jan 20, 2013
    No CSA points charged for size or weight violations. Securement, proper safety lighting, signage, flags etc there are points charged for those violations butttt remember, PONTS CAN ONLY BE CHARGED IF GIVEN AN ACTUAL DOT INSPECTION AND THE VIOLATIONS ARE LISTED ON THE INSPECTION FORM. Paper ticket with a vehicle code violation listed is not an inspection!!!!!!!
    pattyj Thanks this.
  6. fuzzeymateo
    fuzzeymateo Heavy Load Member
    771
    783
    May 20, 2013
    AZ
    Maybe that's the way it is in FL but it's not in AZ. A few years ago AZ passed a law that said overweight tickets will go on your license. And yes it is a CSA points violation. How many? I can't tell you but you can look it up. Pretty much everything will go on your CSA. Getting the ticket for 50 bucks is the least of your worries and......not even 7 years ago you could have paid this and there would probably not have been any more consequences. Before you pay it I would check-out exactly how pleading guilty will impact you.
  7. fuzzeymateo
    771
    783
    May 20, 2013
    AZ
    I stand corrected.... There are no points assessed. Hard to believe but that's what it says.
    tbh1957 Thanks this.
  8. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,727
    Jan 30, 2010
    keep stroking.
    only time csa points are assessed are during an inspection, if there are violations.
    fuzzeymateo and Ghost Ryder Thank this.
  9. fuzzeymateo
    771
    783
    May 20, 2013
    AZ
    BTW overweight tickets do not go to the company. You are the captain of the ship. You are responsible for loading it so you are responsible if it is overweight. Some companies will tell you they will pay the ticket if you receive one and in some cases they will but....this purely a courtesy on their part.
    pattyj Thanks this.
  10. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,733
    Apr 18, 2010
    Tennessee
    What's to contest? Pay it, learn from the mistake and move on.
    Set you a load weight that I don't have to scale out/I do have to scale out weight. As a newer driver I would scale more frequently until you know your limits and how to balance your load out.
    Like my last truck I had a pressure gauge and I wouldn't scale unless I was over 38K just to be sure. When I pulled off the dock most of the time I could get within 2 holes even heavy. When you have less than 26 pallets try to extend them out to the 44'-48' mark to give room to slide your axles and meet most bridge laws. Then put the end of the last pallet a hole or two past the center of the rear axle and you'll be pretty close to right. That's considering you have pallets of similar weight.
    But when your company reimburses for scale tickets don't hesitate to scale out. The more experienced you get the better you will get at it. Sometimes you have to pay for experience! :)
    I always looked at scaling out as a game to see how close to right I could get before hand. I very rarely had to do a reweigh.
    g.o.a.l, pattyj and Ranger Bob Thank this.
  11. Blind Driver
    Blind Driver Road Train Member
    3,081
    1,406
    Aug 7, 2006
    New Albany, IN
    Pay your fine. Don't expect the company to pay for something you did. Duh.
    pattyj Thanks this.
