Anytime is rains my ABS and Traction control light on the dash comes on, and this is the fault it's showing....
Any ideas?
2020 Peterbilt 389
Thanks
SA Left Wheel Speed Sensor
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by JonJon78, Feb 16, 2024.
DeereRunner97, D.Tibbitt and 4mer trucker Thank this.
Most likely a wire rubbed on the ABS chassis harness between the cab and the LF steer wheel speed sensor. When it rains the water increases the continuity to ground and turns the light on.
SA= Steer Axle
Un plug the sensor wire and look for corrosion
D.Tibbitt Thanks this. -
Too bad they aren't all this easy to find. Right in front of my face. One of the rare occasions I walk out of the dealership spending less than $100 bucks on a part. Plug&play.
DeereRunner97, D.Tibbitt, Goodysnap and 1 other person Thank this. -
I'm getting this message now. Doesn't happen when it rains, generally only when I accelerate fast. Guessing it doesn't have a way to tell exactly which drive axle it is so, it only says "AA" for additional axle?
DeereRunner97 Thanks this. -
Replaced LF drive as recommend here, and the problem is gone, no warning messages on the dash at all today.
Thanks again.FullMetalJacket, DeereRunner97, D.Tibbitt and 1 other person Thank this.
