S-Cam turned too much and locked brakes. How to release it?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by ichudov, Jul 30, 2023.
  1. ichudov
    ichudov Heavy Load Member
    742
    641
    Mar 14, 2012
    Berkeley, IL
    On one wheel, the brake pad wore out too much, so when I was adjusting the brake adjustor, the S-cam turned through and is now stuck and the brake is locked. How can I unlock this brake and turn the S-cam back?
    Thanks
  3. Hammer166
    7,339
    26,325
    Aug 18, 2007
    ~8600+' and loving it!
    You'll need to adjust that slack and use a brake application to force the cam to pop the rest of the way around. That's assuming the roller is close to the tip of the S-cam and there's not something going on.
    Oxbow, ichudov, AModelCat and 2 others Thank this.
  4. AModelCat
    154,238
    I'd be willing to bet your drums are worn past their limits and that's why it cammed over.
  5. ichudov
    742
    641
    Mar 14, 2012
    Berkeley, IL
    Yes, it happened because the drums are worn, but I need to release the brakes to drive the trailer to the mechanic.
  6. 201
    201 Road Train Member
    12,044
    24,581
    Apr 16, 2014
    high plains colorado
    I think we've all been there, turned an S cam over. What I did, is disconnect the brake actuating rod, if you can, or remove the whole brake chamber. I think DOT allows 1 brake to be inoperative, but if one cam turned, the others are close behind.
  7. OLDSKOOLERnWV
    17,804
    268,358
    Small 18” pipe wrench can be your friend…..
    Hammer166 and Oxbow Thank this.
  8. Big Road Skateboard
    5,685
    29,598
    May 2, 2021
    If you can hit the back of the slack adjuster down near the rod, it'll cam on over
    Oxbow Thanks this.
  9. ichudov
    742
    641
    Mar 14, 2012
    Berkeley, IL
    Awesome, thanks. I released the brakes (chocked the wheels also) and kept adjusting the slack adjustor further. At some point S-cam "clicked" and the brakes released. I made a few more turns just to stay safe and now the brakes are released, though inoperable.
