S cam replacement
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Dino soar, Aug 18, 2018.
  1. Dino soar
    Dino soar Road Train Member
    4,789
    26,858
    Dec 8, 2017
    I'm replacing s cams and bushings. Meritor kit number 8042.
    This is my first round with replacing these but it looks pretty straightforward I see the bushings and I see the seals.
    My question is that I also see o rings in this kit. Is that for the S cam housing? Is it necessary to remove the housing when you replace the S cams and bushings?
  3. spsauerland
    spsauerland Road Train Member
    4,296
    10,886
    May 31, 2010
    West Harrison, In
    Blue ones? For in between s cam bracket and spider. No need to replace if not leaking grease. Bolts usually break off. I usually just remove the whole spider assy when replacing bushings and seals.
  4. Dino soar
    4,789
    26,858
    Dec 8, 2017
    Yes the blue ones. I don't think they are leaking but I'll take a closer look when I get back down to the garage.
    Also they gave me 2 larger snap rings and two smaller snap rings.
    There is only one snap ring that goes on the end of the slack adjuster. What are the other ones for?
  5. AModelCat
    154,581
    Usually they're a generic kit that covers several cams. The Euclid kit I used came with a couple different sized snap rings and a bunch of misc shims.
    W900AOwner, SAR and Dino soar Thank this.
  6. Dino soar
    4,789
    26,858
    Dec 8, 2017
    Thanks for the replies.
    I can get back to work now.
  7. drdesl
    drdesl Light Load Member
    218
    388
    Oct 7, 2015
    Billings, Montana
    The larger snap rings hold the s-cam in to the spider, the smaller ones hold the slack adjuster on by the inner bushing. The kits usually contain hardware to do an entire axle, hence the 4 snap rings. Hope i explained it clear enough.
