Running under someone's authority when yours is active
Discussion in 'Ask An Owner Operator' started by Edjahman, Jun 8, 2022.
  1. Edjahman
    Edjahman Medium Load Member
    648
    444
    Apr 2, 2013
    Can you run under someone's authority when yours is active or do you have to suspend yours first?
    Ty
    Dadetrucking305 Thanks this.
  3. ibcalm19
    ibcalm19 Road Train Member
    1,463
    2,435
    Nov 30, 2015
    Pennsylvania
    Edjahman Thanks this.
  4. Edjahman
    648
    444
    Apr 2, 2013
  5. pumpkinishere
    pumpkinishere Heavy Load Member
    945
    4,984
    Apr 21, 2021
    You can run under someone’s authority while yours is active. We worked at a company before getting our own authority and once we got our authority. We stayed with the company to let our authority age for 3 months and then we left that company and ran under our own numbers. Your truck needs to be listed in the IRP of the authority your running under. Cannot be 2 IRP accounts. If I remember correctly.
  6. ProfessionalNoticer
    2,941
    7,852
    Apr 25, 2021
    Never suspend yours unless it's unavoidable. You don't want gaps in your insurance timeline. Your IRP will need to match the authority you're using and it must match the numbers on the door.
    Basically, plates, insurance and DOT number all go together. Just trade between them when you're hauling with each one.
  7. roundhouse
    roundhouse Road Train Member
    3,130
    7,038
    Jul 11, 2018
    So how does trip leasing fit into this ?
    i knew guys that would trip lease , they’d use masking tape and stick a new sign on the door , for a couple days or a couple weeks .
  8. TallJoe
    TallJoe Road Train Member
    7,490
    16,271
    Apr 12, 2016
    Chicagoland
    Check this with your insurance agent first!
    I remember a podcast discussing it a while ago. I think it was one of those podcast co-hosts that used Kevin Rutheford's site. So, if I remember the discussion correctly, it was explained like this:
    Once your authority is active, it means that your insurance is active and then it may become problematic when you lease on to someone else and in effect use their insurance for liability and cargo, while yours remains still active. In case of an issue, you have two active insurance carriers, and the one from the company you lease onto may see it and refuse the claim, wanting you to use your own insurance, which in turn, seeing that you operated under someone else's authority when the issue happened, may tell them to pound sand too.
    Lav-25 Thanks this.
  9. ProfessionalNoticer
    2,941
    7,852
    Apr 25, 2021
    How would anyone even know if it's not mentioned?
  10. Wasted Thyme
    7,729
    38,304
    Jan 27, 2020
    GOAT watching
    Because insurance companies always look for a loophole to avoid paying. They'll investigate and find the other insurance.
  11. Arctic_fox
    3,869
    19,527
    Sep 16, 2016
    Easiest way to avoid this is buy a junked parts truck for $5000 or something and stuff it out of the way someplace. Insure that one with your own auth to keep it active and use the others auth on your own truck. If you need to use your own auth on your work truck occasionally then you need to work it out between your insurances though.
    Lav-25 Thanks this.
