so today i finnally got around to setting the overhead on my mack, as much as i hate to admit it i have never had the overhead done on this truck, of course when i bought it had very few miles on a rebuild but now with about 300k on the rebuild and my fuel millage has seemed to be worse lately. i figured i better get it done. now i have also never done the rack on a semi back when i had my freightliner i had it done by a shop. i don't really use any shops for anything anymore and have done valve lash adjustments on auto's many times and have the literature that includes the procedure for my engine for setting the valve lash so not something i felt uncomfortable with in the least. took me probably 4 hours start to Finnish.
i wanted to share something i found very odd when i did the overhead on this engine that does not seem quite right to me, but having never done it myself i thought i would ask if its normal to find this when running the rack or was the rack was never properly set when the engine was inframed?
i checked the valve lash on each valve prior to adjusting them and here are some things i found odd
most intake valves were vary tight the tightest one i could feel a tinny bit of lash my pushing on the rocker arm but i could not get a .001 feeler gauge in there. spec is .016 with the exception of #3 witch was dead on .016 and #6 witch was .014 all the rest of the intakes had less than .003 lash.
exhaust valves all sloppy loose. with the acceptation of #3 again witch was only .025 (spec is .024) and #6 witch was .22 (too tight) all the rest were .028-..30
now for the jake breaks old spec is .015 new spec for updated jakes witch i have are .021? anyway i chose to set them at .015 but here is what i found for pre adjustment lash on the jakes #1 couldn't get a .001 feeler gauge in there it was so tight #2 .027 #3 .018 #4 .021 #5 .010 #6 .016
anyone else find it odd how far allover the place the lash was before adjustments?
i haven't drove the truck sense running the rack but it does seem to idle smoother now.
running the rack
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Ezrider_48501, Mar 4, 2017.
First of all they dont call it running the rack anymore. No ones running a 8v92 here .lol there is no rack in your engine. Your setting the overhead.
Im not familiar with a mack but the only thing i can think of is you were adjusting the valves in the wrong sequence. Are you using the valve overlap method??
If everything was correct then its possible the over head was just that bad out of adjustment. Or something else ive found many times is the guy who set it originally did a real sub par job.
Intakes are common to tighten up. Actually all valves tighten up as the valve recedes into the head with wear.
Only time something gets loose is if you have a bad rocker or cam lobe.
Either way sounds like it was time.Bean Jr. and Ezrider_48501 Thank this. -
yeah the first set of valves i did and the exhaust being so loose first thing that went threw my mind is cam shaft. these mack engines are a bit known for eating cams and the cam was not done at the time of the rebuild. but the fact 4 out of 6 were about the same amount of looseness did ease my mind a little i doubt the engine is eating 4 exhaust lobes at the same time. i expected them to all be tight. and no idea why the jakes would be out of wack so much and not necessarily in sequence with the exhaust valves that were out of whack.
as far as being adjusted out of sequence that was triple checked when i first realized things seemed odd in the pre-adjustment valve lash. timing marked lined up on the flywheel opposite cyl in the firing order in valve overlap between exhaust and intake. adjusted the cyl tdc compression stroke as the procedure outlines. even moved the cyl 15* down the cyl on the power stroke after making the valve adjustment and double checked just to be sure i wasn't out of sequence or on the wrong stroke.
but just from doing valve adjustment on automotive i found this to be very odd, typically what i would find in automotive is the lash would tighten up and typically the exhaust would tighten up more so than the intake would. so it seemed quite odd to me that exaust valves as a majority would be loose and intakes would be very tight as a majority.
the only thing that really comes to mind is the procedure outlined that the valve adjustment is to be done cold, that the engine must be under 100*f. maybe they previously adjusted the valves hot and as exhaust valves run hotter than intake valves maybe that would explain the looseness on the exhaust valves?
of course that doesn't make sense that they would have set the lash hot during a infame cause the lash would be set when assembling the engine before it was run for the first time i wouldn't thing they would assemble it test run it and then re-adjust the lash before sending it out the door.Last edited: Mar 4, 2017
There's only .002 difference from hot to cold valve lash on cast iron heads on gas engines. On aluminum its more. If the head bolts were stretchings seems like all the valves in that head would be too much and would have head gasket problems. Sounds like you understand how things work and maybe a bonehead did the last overhead. Did the pushrod ends show signs of wear?
ProfessionalNoticer Thanks this.
Yes the old 2 stroke jimmys had the "rack" that was a bit of an art to set correctly. It had to be just right for them to run good. Totally different then todays diesels
My first attempt at running the rack was on a 475 silver 8v92. Lets just say i had a old timer from cullen detroit fix it after i thought i did a good job . Lol -
It's not uncommon to see them all over the place if it's never been done. I do the initial adjustment on a new truck at 50-75K miles and that is usually the worst one. It seems that the factory doesn't do a great job or things settle in differently when it's new. After that, they're usually more consistent unless there's a problem. It's also not uncommon for the intakes to tighten up on Macks (Detroit S60's are the same way).
SAR Thanks this. -
I was told DD15 do that, too.
Needed to be done at 70s or thereabouts, but we do idle as needed.
If it isn't done, it can cause parts failure, the valve train broke on a 14 liter 60 series I was driving, it ran better than ever after it was repaired and the overhead run.SAR Thanks this. -
I ran the overhead on a Detroit yesterday and on every cylinder one intake and one exhaust was tight. The other was right on the money. The guy just had the motor put in and I am not sure if they tried to adjust them or what when they put the engine in. Never seen them like that before. He was having high response times on injectors and I put a new harness on and adjusted everything while I was in there. The old harness looked like it was exposed to high heat or something. After adjustments and new harness response times were back to normal.
SAR Thanks this.
