Running lean meaning?!
Discussion in 'Experienced Truckers' Advice' started by missjhawk, Jul 8, 2018.
  1. missjhawk
    missjhawk Medium Load Member
    571
    324
    Jul 24, 2013
    nutbush
    I have a 13 587 pete with a Cummins isx st
    I had it for almost 3 months now
    My clutch fan stop working found a shop patched till I can get fixed at home this week the dealer wanted $2000 and 3 days just 2 fix fan then I notice water leak on ground in middle of motor get 2 my shop they put some pressure thing on it said it was water pump said it was good I can just pay 1 time to tear front of truck apart I have put 26,000 on since I purchased trk I did 1st oil change shop told me a while back to put gal of lucas in trk did that couple times with new oil shop said get 10 oil and 2 gal lucas to help with oil pressure when shop changed oil it was no water in oil, no metal but shop said they noticed i maybe fuel in it they said my TRK IS RUNNING 2 LEAN i they asked how much fuel I go thru and how much power under a load i have they said i need to check my injectors with that said WHAT DOES TRUCK RUNNING LEAN MEAN?, WHAT DOES HE MEAN FUEL MAY BE IN MY OIL? DID MY FAN NOT WORKING RIGHT CAUSE MY WATER PUMP TO START LEAKING? The parts and everything for my truck was about $2000 the shop charged me $700 for labor he said since I was loyal to his shop he would not explain why I thought I was going 2 have 2 put labor on a lay a way plan because of what the dealership was gone charge me
  3. blairandgretchen
    13,225
    70,374
    Dec 9, 2011
    South west Missouri
    Start a maintenance fund and stock it up.
    You need to sample your oil, and learn to read the results. If you have fuel dilution from injector issues you’ll wipe out bearings.
    Not benchtop sample - laboratory sample.
  4. Dave_in_AZ
    370,140
    Fuel in oil is a lot different than just fuel dilution in oil. Fuel dilution is trace elements of fuel from idling a lot.
    Have an oil sample done when you get about 10,000 miles on your current oil.
    Personally I think Lucas is snake oil that costs a lot of money with no benefit. Just use a good oil like Mobil or Chevron.
    By your fan clutch " not working " ; You mean it didn't kick on at all, or it stayed on all the time?
  5. baha
    baha Road Train Member
    4,137
    2,835
    Jul 25, 2013
    ga
    You can buy a oil anl. kit at most truck parts stores for less cash than truck stop charges, like truck pro or most napa parts stores that sell truck parts.
  6. Rubber duck kw
    6,092
    17,685
    Dec 9, 2017
    Just put some Lucas in your oil once and try it. My e model will run a little smoother and leak less with a gallon of that in it.
  7. Dave_in_AZ
    370,140
    Snake oil.
  8. AModelCat
    154,368
    Fan has nothing to do with water pump failure.
    Oil samples. Every oil change. Not only are the beneficial to track possible problems but it can add resale value if you can pull out a stack of oil sample reports to show a potential buyer. We use CAT SOS on everything in our fleet.
    nowright Thanks this.
  9. Trucking in Tennessee
    Trucking in Tennessee Road Train Member
    3,740
    5,739
    Mar 19, 2018
    Nashville
    Every combustion engine runs best with a specific air/fuel ratio. A diesel is close to a gas motor, about 14.5 to 1. More if turbocharged. Motor may run faster, but you can burn a piston doing it. Sounds like injectors aren't flowing well. Gallon of Lucas fuel treatment might help.
  10. tnevin225
    tnevin225 Road Train Member
    1,166
    1,601
    Jan 1, 2014
    I think in general it is, but if you have a fuel dilution problem it help save your engine until you can get the problem fixed, and that would be the only time I would use it.
    Dave_in_AZ and blairandgretchen Thank this.
  11. Rubber duck kw
    6,092
    17,685
    Dec 9, 2017
    No it will actually slow down leaks, and if you've got a 350 Chevy that likes to lose all oil pressure at a stop sign put a gallon of Lucas in and see what happens.
