Runaway Cummins
Discussion in 'Peterbilt Forum' started by Oddball, Jan 31, 2018.
  1. Oddball
    Oddball Bobtail Member
    15
    8
    Oct 11, 2010
    Yesterday morning, I started the 1995 Pete 379 I have been diving for last three years. Cummins engine (sorry, don't know model). All normal until I started feathering throttle to get air up. Barely hit pedal and the engine instantly went to WOT. Turned key off and NOTHING HAPPENED - ending kept running flat-out. This was totally new to me and in fact I've never even heard of it. RPMs too high to put in gear and kill it that way. Another driver saw what was happening and ran over. I showed him the key, out of ignition. The truck has a kill switch and he hit that. RPMs dropped slightly and motor started running very rough. Finally Rs dropped low enough I could get it in gear and kill engine. Whole time it was running, other guys said thick black smoke pouring out of the stacks like a locomotive.
    Boss arrived about then. He restarted the truck (kill switch off) and it did not go wide open, but ran pretty badly, again with lots of smoke coming out.
    He theorized a seal might have broken in turbo causing it to pump oil in to intake, which sort of made sense.
    Anyone else out there ever experience this, and if so what caused it?
    FWIW, I've been driving for about 8 years now and still consider myself a newbie. I learn something new every day and would sure like to put this one in perspective. BTW, I didn't need any coffee to wake up that day!
  3. Diesel Dave
    8,520
    23,433
    Jan 20, 2010
    Hesperia, Ca.
    Yes, the oil leaking in the turbo was the culprit. The only way to kill it is to choke the intake on the turbo. Oil will burn. Put oil in a smoke pot and it will burn for days.
  4. Oldironfan
    Oldironfan Road Train Member
    5,777
    5,541
    May 22, 2017
    What color was the engine? I'm guessing it's a n14 if it's black and has a ecm.
    Diesel Dave Thanks this.
  5. Diesel Dave
    8,520
    23,433
    Jan 20, 2010
    Hesperia, Ca.
    Good point, I was thinking of the mechanical ones.
  6. pushbroom
    pushbroom Road Train Member
    1,777
    7,253
    Sep 1, 2012
    Injector stuck open, turbo failure, something along those lines. Motor has to come apart regardless, damage is done. Had one run away in the shop. Filled the whole shop with smoke. Ecm recorded 2700rpm before key was turned off. Killed it by shuting off the fuel tank taps. Got a crank, block, kits, fuel pump and 6 injectors.
  7. mitrucker
    mitrucker Road Train Member
    5,140
    8,804
    Dec 15, 2010
    Lapeer, MI
    Had a 2013 Prostar do it at 50k miles. Put a rod out of the side of the block. Turbo failure.
  8. Oddball
    15
    8
    Oct 11, 2010
    Appreciate the replies. Engine is tan in color. I’m still thinking turbo since the kill switch cuts fuel off (doesn’t it?) - which I think would mean it couldn’t be injectors or fuel related at all ... right? FWIW, this is a replacement used engine of unknown mileage that up until now has run fine. We swapped it for the previous one that DID put a rod through the block, but not for same reason.
  9. pushbroom
    1,777
    7,253
    Sep 1, 2012
    Kill switch as in a air shut off like a roda shut off?
  10. BigBob410
    BigBob410 Road Train Member
    5,665
    74,100
    Feb 2, 2016
    Beirut on the Bay, MD.
    @Oddball look on YouTube search runaway diesel. It's a fairly common occurrence.
  11. I glide 47
    I glide 47 Road Train Member
    1,426
    1,523
    Jun 3, 2017
    Tan engine means big cam 3 or 4 could be anything from shinny 290 to a 444 maybe a kta 600 good luck
