Rubber bushings v.s. polyurethane bushing?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by snowman_w900, Apr 21, 2014.
  1. snowman_w900
    4,418
    81,024
    Nov 25, 2010
    getting ready to do the spring pin bushings on my 06 t-600. the factory bushings are rubber, the spring pin is made into the rubber bushing so they are none greasable and they are pressed into the spring eye as an assembly.
    question is, has anyone used the polyurethane aftermarket bushings sets? just lookin for somefeed back before i buy my bushing sets.
  3. eeb
    eeb Heavy Load Member
    731
    268
    Mar 24, 2013
    From what I've seen, the rubber bushings seem to offer decent service life. Don't have much experience with the poly bushings, but I've heard they squeak. May just be truckstop lore.
  4. Alaska76
    Alaska76 Road Train Member
    1,228
    1,653
    Jan 20, 2014
    Inland Empire, WA
    The polyurethane are more durable and much stiffer, and often come in colors other than black, they also are more resistant to petroleum/chemicals. No down sides to them really.
  5. bigguns
    bigguns Road Train Member
    2,846
    6,853
    Jun 13, 2013
    Omega,GA
    I would expect a bit harder ride from polyurethane bushings because they are a harder material. Just my .02 cents worth
    chalupa Thanks this.
  6. chalupa
    chalupa Road Train Member
    3,757
    1,643
    Jul 22, 2010
    Houston,Texas
    They are a bit more cash in the front but I use them in the south.......UV rays don't degrade them near as bad as rubber. Excellent choices for SOB hand smash areas like lower radiator supports and torque arms......and they will stiffen up an old suspension. Make sure you use engine build lube or molly grease on all the bolt shafts or they will squeak like a 1960 Ford wagon......( with Faux wood sides )
    ( Multiple colors available too !! )
    Good luck
    bigguns Thanks this.
