Was wondering if any one can tell me what I need to hook up a electronic RPM tach to a PT fuel system. I have a 94 kenworth with a Formula 290 Cummins in it and the tach dont work and need to know were to start looking, It original had a 3306 cat motor in it.
RPM Tach hook up on a PT fuel system
Discussion in 'Trucks [ Eighteen Wheelers ]' started by 94kenworth, Sep 4, 2012.
The Marine and tractor industries use Cummins engines. That's probably the best places to look. Here's one that should work at a nice price. http://www.jamestowndistributors.com/userportal/show_product.do?pid...
My 87 uses basically a speed sensor in the bell housing, it might have just broke a wire, mine is located in passenger side.
The bell housing is the most common spot. Its a 2 wire sensor. If the bell housing doesn't have a tapped hole, stewart warner offers a sensor that runs off the fuel pump tach drive. That sensor may require the use of a stewart warner tach.
The stewart warner may be your only option, the engine I have that started as a 290 does not have the option for the bell housing tach. I believe you do have to use their tach though.
You should have a tapped hole in the bellhousing, my '84 BC III 400 does. It is offset to the passenger side, from bottom center.
