RPM increases during idle
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by TheBigCat, Dec 10, 2017.
  1. TheBigCat
    TheBigCat Bobtail Member
    45
    21
    Dec 26, 2012
    I have a 2016 Freightliner cascadia Detroit engine. I'm sitting here idling (a couple hours) and all of a sudden my rpms jumped from 800 to 1200. And it got a little rough. Should I be concerned? Is this normal? How big of a problem could this be? Thanks in advance.
  3. uncleal13
    uncleal13 Road Train Member
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
    Sounds like it has the Auto Elevate parameter set, it allows the truck to automatically do a Regen while idling. Otherwise you would get a bunch of warning lights and have to initiate a Regen manually.
  4. TheBigCat
    45
    21
    Dec 26, 2012
    Whew! Thanks! I had an idea it may have been doing a regen. But since I didn't see the normal regen stuff light up I got concerned
  5. daf105paccar
    6,564
    7,293
    Apr 15, 2012
    Why do you idle?
    TheBigCat Thanks this.
  6. Heavyd
    Heavyd Road Train Member
    7,749
    6,184
    Feb 4, 2009
    Yes, most engines have some sort of anti-idling strategy to keep the emissions down. Like mentioned, it could have been doing a regen or even just changing air flow strategy through egr valve and turbo actuator changes. They can really change how the engine sounds and even feels.
  7. Justrucking2
    Justrucking2 Road Train Member
    3,211
    4,292
    Sep 12, 2017
    Plymouth MI
    These EPA trucks don't like to idle, not good for the system.
    skellr, D.Tibbitt and TheBigCat Thank this.
  8. Brandt
    Brandt Road Train Member
    4,404
    5,937
    Sep 17, 2012
    I'm driving a 2017 Detroit it has Optimized Idle option. It starts the engine for heat or A/C or battery voltage or engine oil temperature.
    It will also automatically do a parked regeneration. I have noticed at about 6 hours Idle time it will regen. So usually it does one or two times during a 34 hour reset. If I'm just taking usual 10 hour break not needed. It only take about 20 minutes to Regen vs older trucks taking 45 minutes.
    D.Tibbitt, Heavyd and TheBigCat Thank this.
  9. Mattdaddy
    Mattdaddy Bobtail Member
    7
    Jul 7, 2019
    Oh i dont know. Because its July and hotter than Hades. What kind of a retarded question is that? Why is your house air conditioned? An equally stupid question
    Freshboy4, outtatime, Navtech and 4 others Thank this.
  10. D.Tibbitt
    140,801
    Yes my 16 cascadia will do an auto regen, usually lasts 10 to 15 minutes. It does about every 8 hours. And if u keep idling like i have been idling since friday afternoon sitting stuck here at truck stop i have had to do a manual regen where the regen light comes on and u have to push the button. If u ever see that regen light flashing and blinking it means u need to do regen ASAP .
    InTooDeep and FlaSwampRat Thank this.
  11. D.Tibbitt
    140,801
    Yeah well some of us dont have an apu so we do whaf we have to do . it aint my truck so i aint payin the bills on it, if i was i would get an apu because ur right idling destroys these engines
    InTooDeep Thanks this.
