Rope vs rubber tarp straps? Any tips and tricks?
Discussion in 'Flatbed Trucking Forum' started by already gone, May 20, 2018.
  1. already gone
    already gone Road Train Member
    1,482
    801
    Sep 8, 2007
    Western New York
    My current company uses steel tarps with rope attached, no bungee's. It seems slow, as ive only ever used bungees. Does tying knots get faster, or would i be better off untying the ropes and acquiring bungees?
  3. skellr
    skellr Road Train Member
    8,737
    12,184
    Jul 17, 2011
    The Village, Portmeirion
  4. Espressolane
    16,975
    102,327
    Have used rope on all tarps for years. As with anything, speed come from doing the task. How the rope is hooked to the trailer is one factor. Does the trailer have rope hooks under the rail? That can speed things up.
    One thing I do not do is leave the rope in the tarps.
    For rope, I carry 2 each of 100,75,25 foot lengths.
    I do have about 25 bungees for pinning down corners and for the odd spots.
    On knots, using good knots and knowing how to tie them is a key. A truck knot can be used almost anywhere along the rope to make a section tight.
    Do a google search on truck or truckers knot, several videos will come up.
    People call this a knot, it is actually a hitch. In the rope world, you have two major classes of “knots” hitches and bents.
    Rollr4872 Thanks this.
  5. ChaoSS
    ChaoSS Road Train Member
    3,338
    6,755
    Sep 20, 2014
    Are you using long ropes or are you using a whole bunch of short sections of ropes and using them just like bungees?
  6. already gone
    1,482
    801
    Sep 8, 2007
    Western New York
    Short sections tied to the grommet itself, or knotted to catch in the grommet.
  7. ChaoSS
    3,338
    6,755
    Sep 20, 2014
    That seems impractical unless every load is basically the same, or the same height. I don't mind using rope, I mostly use shock cord because I drop / hook loaded and tarped trailers regularly and that's what the company provides. However, I'm fond of using regular rope if I'm delivering the load myself and hanging onto the tarp.
    Either way though, it's a long length of rope, not short sections. Personally I'd switch, but if you don't hang onto your tarps then I'd just learn to deal with it.
  8. already gone
    1,482
    801
    Sep 8, 2007
    Western New York
    Im on a pretty regular run, half of the run is eye to the sky coils on pallets, the backhaul is pipe that isnt tarped. The coils seem pretty consistent in height.
  9. Espressolane
    16,975
    102,327
    You may want to look at a taut line hitch, it’s fast. Easy tie and pull to take out, plus it can be adjusted quick if need be.
    Jazz1 Thanks this.
  10. already gone
    1,482
    801
    Sep 8, 2007
    Western New York
    None of the coils seem much over 2.5 feet high, im thinking about seeing how long i am hooked to the same trailer. If its pretty much permanent, ill just get rid of the majority of the ropes and use tarp straps. I figure right now, bungees would cut .5 to. 75 hour off screwing around with ropes.
  11. supersnackbar
    18,597
    44,717
    Aug 19, 2007
    Your Town, USA
    I haul glass and we ONLY use rope. The company had a driver get popped in the eye when a bungee strap broke, so they outlawed bungies. We carry a 600' spool of rope to replace bad, old or cut ropes...and in 6 months, I am on my 3rd spool.
