Roll off Driver Waste Management
Discussion in 'Questions From New Drivers' started by Molonl4beNC, Jan 23, 2019.
  1. Molonl4beNC
    Molonl4beNC Bobtail Member
    9
    6
    Jan 12, 2019
    Curious if anyone has ever drove for WM or a Rolloff? I found a job here in NC that says they’ll get me close to $22 per hour based on my experience etc... I’ve never drove a rolloff, but did drive a front end for a couple months when I was younger for a shady company and hated it. They wouldn’t follow DOT regulations and I ended up getting 93 1/2 hours in one week. I recall one day in particular that I went in at 3am and I didn’t punch out until 11:45 that night, then had to go home, sleep and be right back at 3am. I was just curious what Waste Management would be like considering it’s a much larger company and the pay is good
  3. Omega7777
    Omega7777 Medium Load Member
    392
    414
    May 21, 2018
    they should put all these rich people into jail because they hardly sleep ;)
  4. WesternPlains
    6,274
    51,408
    Sep 1, 2017
    WM has a rule. Truck gets hit three times. You’re out of a job. No time limit. Doesn’t matter if it’s parked and someone runs into it.
  5. pmdriver
    pmdriver Road Train Member
    2,338
    3,503
    Nov 14, 2017
    Wm is a good company with work that will keep on. It is very political and the ones who are working that plant can make a newbies life a bit hard. Roll off work is pretty easy except you have to tarp them big boxes and sometimes they are a bit over loaded.
  6. Tombstone69
    Tombstone69 Road Train Member
    1,010
    1,346
    Dec 20, 2018
    Jersey shore
    Roll off work is great, after you pull the box on your back, you get to climb a big dirt hill and then drive across a sponge. Back in the 70's I worked for 13 different trash companies,all mob owned.The Feds came in,closed most of them down, now we have WM. I remember one guy used to put his arm around me and say,"do me a favor" which usually meant do something for nothing.I think he's in prison.After I quit he called me up all mad because I had 4 containers stashed in an industrial park.The swag was great too,I don't think I ever had to buy disposable diapers for my first born.I think they frown on that now,might even fire you.Man,I could go on for days about the garbage industry,but like everything else it isn't like it used to be.
    austinmike and Texas_hwy_287 Thank this.
  7. Texas_hwy_287
    Texas_hwy_287 Road Train Member
    2,094
    2,390
    Sep 25, 2016
    Texas
    Waste management decent pay and good hours along with good benefits.
    Cons are facing cameras and equipment is not properly maintain.
  8. Espressolane
    16,967
    102,245
    WM is a reasonably decent company. The pay can be different depending on locations. Some pay hourly, other by the haul or load weight. Just depends.
    Benefits are good and the usual corporate stuff. Used to be about $55.00 a week for full medical for two adults.
    Roll off has seasonal swings, winter will slow down quite a bit. April to September are the busy months, mostly related to construction picking up.
    They have in cab camera systems and GPS tracking in most trucks. If you sit too long with the engine running, you will get a call from dispatch. If you run the engine when you on breaks, you will get a call from dispatch. If the cameras record or live feed you drinking, eating, talking on the phone or a number of other things while the truck is moving, you will be talking to safety and management. They do provide uniforms, you are required to wear only the items they supply. If it is not approved, you will be talking to management.
    Should you get stuck in a mud hole at a location and need a winch out. It is considered an incident. That includes job sites. If for any reason any tire is off the ground, that is a roll over. Roll overs are immediate termination.
    WM has the highest turnover rate in the business.
    Texas_hwy_287 Thanks this.
  9. Texas_hwy_287
    2,094
    2,390
    Sep 25, 2016
    Texas
    They sound more stricter than a freight company. No wonder the turnover is so high.:confused:
  10. rostig4404
    rostig4404 Bobtail Member
    18
    13
    Oct 28, 2015
    Addis, Louisiana
    Check into Action Resources. Not sure of locals in NC.
  11. WesternPlains
    6,274
    51,408
    Sep 1, 2017
    Colin Powell said: There is nothing worse than an insecure leader.
