Rod bearings replacement?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by TallJoe, Jan 13, 2017.
  1. TallJoe
    TallJoe Road Train Member
    7,490
    16,271
    Apr 12, 2016
    Chicagoland
    Is it necessary as a precaution...even if the oil pressure is steady at 35-36.5 psi at 1500 rpm, cummins isx at 900 k miles. Or should I leave it alone since there are no appearant issues.
  3. passingthru69
    Pull the rod caps and check for wear, if good keep trkn
    wore out and TallJoe Thank this.
  4. TallJoe
    7,490
    16,271
    Apr 12, 2016
    Chicagoland
    Ok. I can have someone to inspect it visually. I had better crawl under there and see it myself too.
  5. DougA
    DougA Road Train Member
    1,429
    8,892
    Dec 16, 2013
    Retired,In my shop in Md.
    If they've never been checked by 900k,I would want to look at them.Oil and metallurgy have increased in leaps and bounds since the old days,but if I owned it,I'd want to know,but that's just the mechanic in me.Lot cheaper than putting a crank in.Not the easiest job,and messy ,too.And while your doing it,pull a main or two,and check them.Make sure you check the top bearing on the rods,and the lower bearing on the mains,that's where the wear will be.Do you have a big 3/4 drive torque wrench?In the old days,we just rolled bearings in every 250k,overhaul at 400k+or-,sop.
    TallJoe Thanks this.
  6. wore out
    wore out Numbered Classic
    15,892
    192,204
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    As a rule the top bearing will wear more than the bottom bearing. Worse if it's lugged down a lot. A good indication of bearing wear is a large difference in oil pressure from cold start idle to warm idle
    x1Heavy, SAR, Oxbow and 1 other person Thank this.
  7. TallJoe
    7,490
    16,271
    Apr 12, 2016
    Chicagoland
    I did not realize that you could actually directly see the wear and tear on them from beneath. When I go to the shop and ask about it, I'll also request they let me go down there with them an show me the bearings as they are. Thanks.
  8. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,730
    Jan 30, 2010
    keep stroking.
    You Have to remove top bearings to see wear. Bottom bearings will still be seated in cap when dropped.
    x1Heavy Thanks this.
  9. Superhauler
    12,209
    100,730
    Jan 30, 2010
    keep stroking.
    If the journals on crank look scratchy, you can crocet cloth then to polish them up, DONT USE EMERYCLOTH!
    hellpatrol, x1Heavy and BoxCarKidd Thank this.
  10. Heavyd
    Heavyd Road Train Member
    7,770
    6,210
    Feb 4, 2009
    I think you'll find some minor wear, but nothing that needs replacement. The thing is, why go through all the trouble of pulling the pan and a couple of caps just to inspect? You're 60% there to replacing them now, just go the rest of the way and replace them all. Complete waste of time just to inspect 1 or 2 anyway. If you are content to only inspect 2 and assume the rest are fine, then you might as well assume they are all fine and don't bother to inspect in the first place.
  11. bigguns
    bigguns Road Train Member
    2,846
    6,853
    Jun 13, 2013
    Omega,GA
    ^^^^^^^^^ Well said.
    Heavyd Thanks this.
