rocker box leak help
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by jpgale22, Mar 30, 2019.
  1. jpgale22
    jpgale22 Light Load Member
    149
    15
    Apr 12, 2016
    I have a international 2007 model 8600. It has a cummins Ism engine. My rocker box is leaking oil. I was told by my shop that they have to take out a lot of parts and put new o rings on the injectors. My question are How many labor hours should this take ? I also wanted to know is there anything else I should replace since its im pulling apart a lot part. Or should I do a inframe . any advice is apprciated.
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,418
    6,432
    Aug 26, 2014
    Sounds to me me like you need a different shop. Pulling injectors to repair an external oil leak? Did you misstate something?
    Those are fun to work on. I do not have a labor guide by my recliner but could see 10 hours to replace injector o-rings and adjust everything.
  4. ClineER
    ClineER Light Load Member
    229
    139
    Apr 27, 2016
    N.E. Oklahoma
    Yes u have to pull injectors, solenoids hang over part of intake built in rocket box. I would say 4 to 6 hrs depending on what else is mounted on motor
  5. Heavyd
    Heavyd Road Train Member
    7,750
    6,184
    Feb 4, 2009
    Do I hear 2.5 hours????
  6. BoxCarKidd
    4,418
    6,432
    Aug 26, 2014
    I have not done one of those in 4 or 5 years. If it has the automatic transmission shifter that has to be removed before the dog box. Then remove the wipers and panel below the windshield. Plus the air filter housing. Just the R&R on that is about 4 to 6 hours for me before the real work begins.
    Seems like Cline is correct I retract my statement about your shop. I never just repaired a leaking gasket was always going deeper.
  7. Heavyd
    7,750
    6,184
    Feb 4, 2009
    I'm being totally sarcastic. Rocker box oil leak is down to the bare head. 2007 will be an egr ISM with EGR EGR cooler and all that is part of the rocker box housing. Yes, rear engine cover has to come out, normally wiper cowl too. It's a big job, longer than a day. 4-6 hours is a joke and nothing but corner cutting and sloppy work. Anyone quoting that low has no idea what they are doing and would never touch an engine of mine!
    spsauerland Thanks this.
  8. jpgale22
    149
    15
    Apr 12, 2016
    Yea they told me it was a big job I was wondering since I’m going down to the bear head should I change the head gasket or anything I haven’t never had no engine work done on this truck
  9. jpgale22
    149
    15
    Apr 12, 2016
    You think it will be like a 15 to 20 hour job ?
  10. Heavyd
    7,750
    6,184
    Feb 4, 2009
    I have already said too much, LOL. All these questions do is start arguments. It's about 15. 20 is too high, but 12 seems low too. Sometimes they come apart nicer than others. I would stop here for further repairs because if you want to go farther, you get a reman head and do 6 pistons and liners while you are there too to make it a full overhaul.
    BoxCarKidd and spsauerland Thank this.
  11. spsauerland
    spsauerland Road Train Member
    4,296
    10,886
    May 31, 2010
    West Harrison, In
    I always replace injector wiring harness and RTV around pass-thru connector when doing the rocker box. Oil will leak past the wire seals.
    BoxCarKidd and Heavyd Thank this.
