I have an extendable 3rd axle flip Rgn and am trying to figure out where the center of gravity
Is closed ? Can anyone get me in the right area.
Rgn center of gravity
Discussion in 'Ask An Owner Operator' started by BOM19:26, Nov 6, 2019.
Page 1 of 3
I am not sure what you are asking, center of gravity, or where you need to center the weight, maybe?
OLDSKOOLERnWV, Oxbow and BOM19:26 Thank this. -
I'm assuming you mean the weight center? With a flip up, it'll probably be just forward of the center running/ indicator light. With flip down, it'll be rear of the light
BOM19:26 Thanks this. -
I simply do not possess that kind of advanced knowledge. All I know is a flatbed deck will give you a certain COG along it's length at a certain height, usually around 14 inches the way I have been trained.
IF you are talking about applying a LOAD FORWARDS as in closer to your tractor then thats for weight purposes.
Your axles on your tractor and trailer will be self explanatory against the Maximum weights allowed for your entire rig. If you are capable of scaling whatever you intend to put onto your deck wherever you think it needs to be then you are doing well.BOM19:26 Thanks this. -
That would depend, then, on what your tag is rated for.
Page 1 of 3
