Reverse lights stay on when I turn my headlights on...
Discussion in 'Freightliner Forum' started by powerohana, Jan 18, 2017.
  1. powerohana
    powerohana Bobtail Member
    4
    I have a Freightliner Century Class s/t 2007 with a Detroit 60. The harness to the taillights was corroded and didn't light up correctly. After fixing them and putting them in correctly. I checked that when I take it out of reverse the reverse lights turn off. It did. The next morning because I have a habit of putting the gears in neutral the day before I went ahead and turned the key. The engine turned and made a noise. I want to say it sounded like a snap. I realized it was in reverse so I put it in neutral. I turned the engine on and everything seemed fine except the reverse lights stay on when the headlights are on. What did I break and how do I resolve this issue? Thanks in advance!
  3. mnmover
    mnmover Road Train Member
    1,237
    1,104
    Apr 5, 2009
    Lichfield MN
    Remove the fuse for the backup lights.
    powerohana Thanks this.
  4. powerohana
    4
    Will the reverse lights work after that or do I replace it?
  5. Jarrods
    Jarrods Bobtail Member
    28
    7
    Sep 2, 2016
    Last 6 of the Vin?
  6. powerohana
    4
    W34688
  7. Jarrods
    28
    7
    Sep 2, 2016
    I'd the headlights are off will the reverse lights go out?
  8. Jarrods
    28
    7
    Sep 2, 2016
    If you check the tail light connector(should be a 5 pin plug) make sure that pin A (red wire circuit 120B) is going to the reverse light and pin B (blk wire circuit 23A) are going to the tail lamps. Sounds like one of those circuits got installed in the wrong spot
  9. Jarrods
    28
    7
    Sep 2, 2016
    You can also pull the reverse connector off the transmission. If they stay off with it unplugged then the reverse switch is at fault.
  10. KB99
    KB99 Bobtail Member
    Where is the reverse switch on the transmission
