Reverse Light
Discussion in 'Trucks [ Eighteen Wheelers ]' started by JimmyWells, Oct 27, 2016.
  1. JimmyWells
    JimmyWells Road Train Member
    1,000
    1,078
    Apr 7, 2016
    1994 Kenworth W900L has no reverse light installed. I'd like to install one even though I'm not sure if it's even required since the fog lights on my headache rack can suffice. Anyway, there are three wires hanging near the hole but none have power after checking with a test light. Maybe I'm testing the wires wrong? One is white and has a clasp on the end as if to attach to a ground so I've been assuming that's the ground wire. The other two have paint on them and cannot tell exactly what color they are but both have the male prong type terminals in them.
    My light only has two wires so I have no idea which wires to connect. Input?
    Also, is there a fuse for the reverse light? I don't see one specifically labelled for the reverse light but i've heard they can sometimes been tied into other circuits.
    How about the reverse light switch that usually on the transmission? It's an Eaton 13 speed and I've read here that on 379s their under the panel where the boot is at the bottom of the shifter. Are they located in the same place on a W9?
  3. HopeOverMope
    HopeOverMope Road Train Member
    1,801
    3,210
    Feb 25, 2016
    I-20 LOUISIANA
    That was a lot of questions at once! But all good ones. I had the same problem recently but in reverse, no pun intended haha but.... My lights had three prong connectors and my power source was only two wires. Long story short I went out and bought the $5 cheap-e's that used the 2 prong connectors.
    So you may have to invest into a 3 prong light,,,:::: my older Volvo has a back up lamp fuse, 10a.... And as far as the test light, good luck with that,,, gotta have a real good ground to work right... It was suggested to me earlier to test it on a battery if one is unsure if it's working properly.
    The transmission switch is pretty easy to change and mine was $20. Passenger side of transmission on top. It's a thread-in sensor that was a plug on top. That was on a Meritor. I crawled underneath to do it
    JimmyWells Thanks this.
  4. JimmyWells
    1,000
    1,078
    Apr 7, 2016
    Thanks for the input. I removed the shifter boot and was able to locate the back up switch. After using my test light to confirm it was working properly I scoured the harness traveling the frame. I was unable to determine the break in continuity so I opted to run a new wire from the switch to the light. Problem solved!
    HopeOverMope Thanks this.
