Retreiving Codes '07 387 Cummins ISX
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Blind Driver, Jun 29, 2013.
  1. Blind Driver
    Blind Driver Road Train Member
    3,081
    1,406
    Aug 7, 2006
    New Albany, IN
    Started getting a check engine light the other day.
    Google told me to....
    Use the following procedure to retrieve the flash codes if the engine is equipped with a diagnostic lamp:
    1. Turn the ignition key to the ON position/Engine off.
    2. Turn the cruise control ON/OFF switch to the OFF position.
    3. Move the SET/RESUME switch to either position. Hold that position until the yellow lamp begins to flash.
    The yellow lamp will flash in order to indicate a two digit flash code and the SET/RESUME switch may be released. The sequence of flashes represents the system diagnostic message. Count the first sequence of flashes in order to determine the first digit of the flash code. After a two second pause, the second sequence of flashes will identify the second digit of the flash code.
    All Flash codes are 2 digits.
    But I get no flashing lights :(
    Any ideas?
  3. highside
    highside Medium Load Member
    441
    510
    Feb 6, 2010
    Kansas
    That procedure only applies to a CAT engine. For a Cummins, if you don't have a diagnostic switch on the dash, or a Road Relay unit, you'll have to hook a computer up to it to read codes.
  4. Blind Driver
    3,081
    1,406
    Aug 7, 2006
    New Albany, IN
    I was afraid of that :(
  5. jdutton1
    jdutton1 Bobtail Member
    32
    I have 06 378 with six and diagnostic switch on dash. How do i manually pull codes?
