Restrictive fuel fitting Detroit s60 12.7
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by crucar1800, Sep 7, 2022.
  1. crucar1800
    crucar1800 Light Load Member
    186
    71
    Sep 21, 2012
    hi! Can someone please help me out understanding this fuel flow diameter.
    This is a fuel fitting located on the rear of the engine. Its inner opening is about 1 mm in diameter and it connects to a brown fuel line of half inch in diameter. It is also referred as a restrictive fuel line. Question: what would happen if the fitting is replaced for a normal opening fitting instead of the 1 mm flow? from 1 mm to a regular approx 1/2 inch flow of a normal fitting. thanks!
  3. Big Road Skateboard
    5,687
    29,608
    May 2, 2021
    You'd have no fuel pressure. That restriction is what regulates pressure
  4. crucar1800
    186
    71
    Sep 21, 2012
    thanks big road.
  5. AModelCat
    154,281
    Yup that is what gives you pressure in the fuel passage in the head.
  6. Rideandrepair
    17,209
    55,828
    Aug 8, 2015
    Top fittings the return line. Returns fuel to tanks. It’s 0.080 in. (2mm) Some swear by drilling them out to 0.090, Others claim you can drill it as much as 0.105 and still have adequate pressure in the head for injectors. The idea or theory is that by returning fuel faster, it stays cooler, and therefore burns or atomizes better. It’s probably the oldest and cheapest trick on a 12.7. I’ve never done it myself. Always wanted to try it though.
    Big Road Skateboard Thanks this.
  7. Big Road Skateboard
    5,687
    29,608
    May 2, 2021
    My dad had unlimited time and a dyno in the early 90's to do testing on engines, tuning them different ways to see how mechanical changes affected torque and HP.
    On the 60's, he found a fuel pressure of 68-69 was pretty well optimal. He said even small differences of 3-4 psi were worth changing.
    Most 60's from the factory were in the 75-80 range. And my most used bit for acheiving that 68 PSI was a .117.
    I was just a dumb kid back then (not much change today), but dad taught me his methods as soon as i started. Folks came from all over for his tuneup procedure, which included very particular injector and valve settings. This was back before tuning ECM's were even a thing..
    Back then, 80% of rated HP to the wheels was considered standard. The best i did and dynoed was a 500 putting 508 to the ground.
    Rideandrepair Thanks this.
