Reset ecu or entire truck system.
Discussion in 'Ask An Owner Operator' started by Ikamob01, Jun 23, 2023.
You have to remove the ground cables first regardless. Very dumb idea to take only the power cables off - touch ANYTHING metal with your wrench and you're making major sparks. Its essentially a dead short right on top of your batteries.
Ground cable will open the electrical system anyways.Keepforgettingmypassword, InTooDeep, Magoo1968 and 3 others Thank this. -
That’s why I like a power shut off switch on the shakers . If I’m home for the week I shut off power.
Keepforgettingmypassword and Long FLD Thank this. -
Why are you reseting? Did you get a code?
Def tank low after installing a new def sensor.
Magoo1968 Thanks this. -
Might have to be recalibrated and not just turned off and on.
Siinman Thanks this. -
You may need to fill the DEF tank full to calibrate the level sensor.
I don't think unhooking the batteries will do anything.
What engine and make and year of truck? -
It’s the positive that needs to be disconnected to reset, but of course negative needs to be off first. Also need to try to remove whatever is left by hitting the brakes couple times. But it may not help in your case regardless. Sounds like calibration issue or new thing is faulty too.
Is an ecu an ecm? Why not disconnect batteries?
