Requirements for a non CDL hotshot setup.
Discussion in 'Expediter and Hot Shot Trucking Forum' started by Wheelman90!, Oct 18, 2021.
  1. Wheelman90!
    Wheelman90! Bobtail Member
    I have a class A CDL but I’m setting on a non CDL hotshot setup . Im in Alabama what kind of plates are required
  3. crocky
    crocky Road Train Member
    1,732
    1,577
    Jun 28, 2017
    Usually, you will need the normal plates that go on that truck then have the tags rated for the 26k. I dunno if all states do the weight rating on the tags for non-apportioned but here in FL they did when I ran as non CDL.
    Wheelman90! Thanks this.
  4. ZVar
    ZVar Road Train Member
    10,911
    23,825
    Sep 10, 2010
    Flint, MI
    Your license has zero bearing on your registration. They both go off GVWR sure, but while you can register for less weight, your CDL is based on GVWR and not the registered weight.
    What is the GVWR and will this be intrastate or interstate?
    Lite bug Thanks this.
  5. Mjordan1379
    Mjordan1379 Bobtail Member
    I driver for my mom and dads hauling company. I wanted to ask if 1.25 per mile a fair pay. I have to pay for my fuel dead heading to get boat and to go home. Also, I am using their truck. Last run I made 670 and after fuel and expenses I made 120.27.
  6. TA1199
    TA1199 Light Load Member
    114
    78
    Sep 12, 2015
    Staten Island, NY
    Welcome to the business. You should be charging $2.50 per mile for all miles, plus a fuel surchage. You could work at Home Depot and make a $120 a day without any headaches. Don't run cheap.
    Most drivers that drive for someone do a 60/40 split. That's pretty standard in the industry if the driver is paying fuel and tolls.
  7. baerpath
    baerpath Light Load Member
    57
    77
    Nov 2, 2019
    So your running a 536 mile trip, that should pay minimally $1340. Sounds like your parents don't have a clue about their cost per mile
  8. Doubletime336
    Doubletime336 Bobtail Member
    May 8, 2022
    bump
  9. Doubletime336
    May 8, 2022
    To be honest it takes some understanding of all the different weights. first if you have a f350 or 3500 or anything of the sort its going to have gross combined vehicle weight rating GCVWR over 26,001lbs (fully loaded truck plus fully loaded trailer) regardless if it really is lfully loaded or not.... its the rating that counts that is over 26,001 lbs this is only one aspect of the calculation... i have an 2015 f250 its GCVRW is 24000..truck has GROSS VEHICLE WEIGHT RATING of 10,000lbs and my trailer has a GROSS VEHICLE WEIGHT RATING OF 14,000 LBS that eqauls a GROSS COMBINED VEHICLE WEIGHT RATING OF 24,000 lbs no cdl required
  10. Todd727
    Todd727 Medium Load Member
    300
    583
    Jun 7, 2021
    You can order a 350/3500 with a 10K GVWR option. Add a 16K GVWR trailer and good to go at 26K.
  11. Gonzo1300
    Gonzo1300 Light Load Member
    237
    113
    Sep 30, 2013
    I will say this, stay away from d r a d trailers because they are cracking down on that now and I know for a fact that gatormade did not backup to drive from the same company. Non-cdl set up in this last Blitz in a lot of cases after they inspected paperwork and the truck they pulled them back around to the scale and drop the trailer from the truck. Then they added that way to the capacity of the truck which put most non CDL setups with d-rated trailers in violation. I've been telling you guys for years with the influx of new hotshot drivers and a vast majority of Hot Shot involve accident but the biggest thing is non compliant they're cracking down and they're going to end that
